Ebpv
Old Oct 17, 2005 | 09:30 PM
unluckylow's Avatar
unluckylow
Ebpv
Hey guys looking for directions for removal of the EBPV. Cant find it on here
Old Oct 18, 2005 | 06:21 AM
slc10844's Avatar
slc10844
Does this help?
Backpressure Valve
Special Tool(s) Spring Gauge
211-034 (T74P-3504-Y)
Removal
Open the hood.
Remove the charge air cooler inlet and outlet ducts from the compressor manifold; for additional information, refer to Section 303-12.
Disconnect the exhaust outlet pipe from the turbocharger.
Loosen the clamp.
Pull the exhaust pipe away from the exhaust back pressure valve.
Disconnect the exhaust back pressure valve.
Slide the retaining clip toward the turbocharger housing.
Disconnect the exhaust back pressure valve actuator rod from the exhaust back pressure valve.
Remove the six bolts and the exhaust back pressure valve.
Installation
Follow the removal procedure in reverse order.
NOTE: The butterfly valve should be fully closed when 4.5 kg (10 lb) of force is applied with the special tool.
Using the special tool, adjust the actuator rod length to obtain the specified reading.
Old Oct 18, 2005 | 09:10 AM
unluckylow's Avatar
unluckylow
Kind of I was looking for the diagram with pictures where you put in a 20mm freeze plug, I know its on here Ive seen it and I thought I printed it out but I didnt.
Old Oct 18, 2005 | 11:14 AM
slc10844's Avatar
slc10844
I tried cut and paste. The text took and the pictures didn't.
Old Oct 18, 2005 | 11:32 AM
Fire Rooster's Avatar
Fire Rooster
Do not use this method, The brass and the cast iron expand and contract at different speeds, the freeze plug will eventually come loose and be sucked out the exhaust. If you are lucky it will not get caughtor hit the turbine blades on the exhaust side before it gets out. (ask me how I know this) Best way of removing it and plugging the hole is too, tap the hole and use a NPT plug. Or look up ITP diesel and order the NON-EBPV turbo outlet. It was never drilled for a EBPV and so there is no hole. This is the fix I used the second time around and it is worth the 100.00 bucks or so.
Old Oct 18, 2005 | 05:43 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Rooster, I didn't think you used the 20mm.
Mine has been in place without issue for nearly three years.
Old Oct 18, 2005 | 06:35 PM
Fire Rooster
Heat and I both used the same method, He also had his come out at some point, it makes a louder turbo whistle, he atributed it to the ceramic coating on his inner cooler pipes. I told him of my new sound and how I heard the plug come out on start up one morning. I told him later that day How I found the exhaust leak coming from the hole where the freeze plug was. He also found the same leak in his, and we both fixed them with the Non EBPV turbo outlet, and both eliminated the problem
