dirty oil ?
Old Aug 22, 2005 | 06:37 AM
dunbar15's Avatar
dunbar15
dirty oil ?
The oil in my 2000 7.3L PSD stays pretty clean in between oil changes..
The oil tech's at valvoline say they dont see to many diesels come in with
clean oil. Is this a sign of a healthy motor ?? What causes the oil to get
dark in so many diesels ?? Thanks for any info on this, just curious ..
Old Aug 22, 2005 | 07:28 AM
fordman102's Avatar
fordman102
I just turned 150k on my '99 and the oil stays pretty clean also between changes at 5000 mile intervals. I've always taken good care of this engine and still in great shape. If you are not the original owner I'd think who ever owned it kept up on all his oil changes and what not.
Old Aug 22, 2005 | 12:09 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
the soot levels in diesel exhaust cause the carbon build up (the blackening of oil) in diesels. that is why it gets black so quick. dont worry, the oil is still good. probably means you have a great set of rings on the truck.
Old Oct 18, 2005 | 09:40 AM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
My first PSD ('95) the oil would start turning black at about 1500 miles. My Cat 3208 in my motor home does the same thing. But my 99 PSD stays clean up to at least 5500 miles. That is the longest I have ever let it go. I have 157,000 on it as of today and it still runs just like new. The oil has yet to ever turn the black I have learned to expect from diesel. I have thought a Wednesday engine was the reason. Possible??
Old Oct 18, 2005 | 01:04 PM
SprintRacer26's Avatar
SprintRacer26
my late '99 PSD has about 7000 miles since last change and you can still see through the oil its that clean (Rotella T 15w40)
My buddy bought a 2000 PSD a couple of months ago, when we changed the oil (Rotella), fired the truck up for about 5 minutes shut it off and checked the oil. It was already dirty, couldnt see through to the dipstick. Is this a sign his motor is going sour? His truck seems to run just fine too.
Old Oct 18, 2005 | 01:19 PM
ford390gashog's Avatar
ford390gashog
no the engine is fine that is the soot being suspended in the oil.
Old Oct 18, 2005 | 01:39 PM
Markadeck's Avatar
Markadeck
OK, but so far no one has said they know why some soot up and others don't.
Old Oct 18, 2005 | 01:47 PM
dsldrvr's Avatar
dsldrvr
do you do any or no idling at all ? If there is very little time spent idling and at low rpm's you may not be getting as much soot. On the other hand if the wrong oil is used it may not be suspending the soot as it should and therefore not looking black.
Old Oct 18, 2005 | 03:34 PM
ford390gashog
well it can be the way the engine was built some have better ring seal.
Old Oct 18, 2005 | 03:37 PM
dsldrvr's Avatar
dsldrvr
or the way they were broken in and have better ring seal
Old Oct 18, 2005 | 06:02 PM
edub32's Avatar
edub32
I have 205k and my oil gets pretty dark quick. Is there anything I can do to clean up my engine a little bit? Would running a couple quarts of oil through the engine help?
Old Oct 18, 2005 | 07:52 PM
Markadeck's Avatar
Markadeck
[QUOTE=fordhog
well it can be the way the engine was built some have better ring seal.[/QUOTE]
This is what I have always thought. Being an old drag racer that always built my own (very fast) motors I know that being diligent at every step is very important. I have always used Rotella in the Ford and Syntec in the Cat. $200.00 bucks to change that sucker, but I lost one once and cost me 16 grand to replace and I ain't gonna let it happen again.
