Help Anyone know how to change one? I bought a new one (Fram) Took off cover under right side of dash. Instructions say to pull down on tab. There is no tab on mine , cant see how to get filter out?
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
You probably don't have the cabin air filter, although if you have a narrow cover held on with (as I recall) six screws, you just don't have a filter in it. Don't know about the new trucks, but for the '97 - '03 models, this was an extremely rare option. There was a Ford dealer accessory kit available at one time, but it was discontinued somewhere around 2001.
I bought one of the last F150 kits available about 3 years ago. However many Expys and Navigators have similar ducts, so kits or used parts might be available for them. Also, if you do a search on this forum, you will see how to put a cabin air filter in your truck without the kit. Apparently this works quite well.
