Electrical Question
Old Oct 17, 2005 | 01:07 PM
97GreenRanger's Avatar
97GreenRanger
Electrical Question
I've got a quick question for anyone who knows a little about the Ranger's electrical system.
I've got a 97 Ranger. On my way home from work this morning all the dash lights that are illuminated when the head lamps are on whet out. The idiot lights still work, ie things like the check engine, air bag, etc lights still come on when I start the car. I've checked the fuses and swapped out the ones that I think are related to the dash lights but it didn't make any difference. Just for reference the fuses I checked were 7, 11, and I think 31. It is the one at the bottom of the fuse panel. Does anyone have any clue what might be the problem?
Thanks in advance for the help.
Old Oct 17, 2005 | 01:39 PM
Cheech5o's Avatar
Cheech5o
does it always do that?
Did it rain at all? becuase when it rained my blinkerlights didnt worl
Old Oct 17, 2005 | 03:09 PM
97GreenRanger
This is the first time this has happened. It rained last week but it has been dry for the past several days. I didn't have any problems Friday or Saturday when I drove it. The only other time I've had a problem like this was with an 86 Ranger that I owned when I was in high school. The solution in that case was simply replacing a blown fuse. In this case that hasn't worked. Either I'm not looking at the right fuse or there is something else going on.
Old Oct 17, 2005 | 04:10 PM
87 XLT's Avatar
87 XLT
This is wired from interior fuse 7 to the dimmer module to the dash lights.
With the lights turned on check for 12 volts at fuse 7, if it's there the dimmer module is probably shot.
Old Oct 17, 2005 | 07:35 PM
97GreenRanger
Thanks for the info. I'll have to go pick up a volt meter and give that a try.
rottenstock
Apr 27, 2013 12:45 PM
Vinford
20
Feb 4, 2013 08:32 AM
SeannyBoy84
Oct 15, 2006 09:57 PM
Ddog1023
Mar 26, 2004 01:31 PM
RClark55
Electrical Systems/Wiring
Aug 23, 2003 11:27 AM
