The ignition power wire should be yellow. You will have to tap into the lighter wire for the memory wire. The blue wire to the stock radio is for the light and is wired into the dash lights. Just tape it up so it won't ground against anything under the dash.
The thing is someone has taken out the cigeretter lighter and took out hte wires also. Most of the wires are taped in electrial tape. All I need is the wire for the memory so the radio keeps its memory but my truck has no cigeretter lighter and I need a place to put my red hot wire. Sorry but im totally lost with wiring.
There I unwrapped some of the tape and found this, Check out my gallery in other to see what wires I found, and maybe you could let me know what goes where and if these are the plugs for the cigerette lighter.
