and that can be found at www.blackclouddiesel.com, and go to 7.3 powerstroke, and "tranny stuff" i have it in my glovebox, i am waiting for my oil to come
I am about to order away off of that black cloud diesel place. Aih delete, dual relief valve, and id really like sonnax/springs kit, and the wicked wheel as well.. Also i ordered a kwik filter, about to do the ccv and wastegate mods and probably will do the mbrp stainless within the next week.
Strokin 7.3, with the edge box that you have, are all the mods you have listed in your sig. And if so, are those mods suff. to hold up to the power the juice puts out?
Only the intake, exhaust, wicked wheel and gauges would be recommended. The ccv has no performance gain, only helps keep everything clean. The AIH mod really has no effect on the performance and not necessary. You will gain a slight improvement in air flow or so they say. When you step up to a custom burned flip chip would the sonnex kit be highly recommended as would an HX mod. Of-coarse any mod you do to beef up something will only help.
Unplugged the wastegate actuator tube from the wastegate, and plugged it up on one of the boost tube bolts. Is it ok to just leave the wastegate tube open with no elbow or cover?
I bought a little rubber vacuum plug at the local auto parts store to cover mine. I don't know if it will hurt anything to leave it unplugged though.
