I have never posted in this forum befor but was hoping that I could get some help. My girl has a 93 Explorer that the gas gadge will not move I have tride
grounding the yellow and white wire that runs to the gadge key on and the
gadge still wont move. Is it the insterment pack or dose the anti slosh modual
play some part in this to.
99 percent that the floater has filled up with gas and needs to be replaced, its about a 5 dollars part to replaced but the tank needs to be droped to replace
I second lawncare1010 had the same problem with mine. Removed skid plate(s)dropped the tank removed pump/sensor assy popped off old flot popped on new one done in 1.5 hrs!
