While I will agree that most railroad equipment does use coil springs, how much suspension travel do they have, and how many coils do they use? The last one I looked at closely had maybe 6" of travel, and 12 coils per side, for a total of 48 coils under the car.
A lot of the reason for leafs instead of coils is packaging. Both are tunable, both can be heavy duty, but only the leaf spring can both locate the axle and hold it down on the road. Plus, leaf springs are flat. You can have a lot more wheel travel with a lower bed height, which is an important consideration.
Chevy used coil rear suspension on the 10 and 20 series from sometime in the early 1960's to 1972. The odd thing is that GMC had leafs the same model years.
I owned a 1971 C10 and one of the best things about it (other than styling) was the ability to go fast on dirt roads. That rear suspension really soaked up the bumps and kept the axle more controlled. The downside to this long-travel setup is that there is much more deflection under load. The difference in hight loaded vs. unloaded was much greater than a leaf setup. I think that, plus possibly cost and commonality with GMC, is why chevy went back to leafs in 1973. Cost had to be more, with the trailing arms, panhard rod, and bushings. It was like having factory traction bars.
I've seen a 67 F100 side by side with a 67 C10, loaded down with the exact same load. Brand new trucks, and the Ford was barely lower in the back. The Chevy back bumper was nearly draggin on the ground. It was no secret back then that Chev had a better ride, but Ford could haul a bigger load.
Like I said, the coil setup has a lot more travel than leafs. That means that it will look higher unloaded and lower fully loaded. That does not mean that the actual load capacity is any different, it just looks different. When a leaf setup is abused by overloading, such as one of my friends does to his Ranger, the leafs bend or break.
Maybe with time i'll come to accept that. Which will probably be around the same time they come out with a truck with a full 8 foot bed, with front wheel drive only. And thats the day i'll stop looking at new trucks.
If the ridgeline wasn't AWD, we'd already have that...minus the 8 ft bed, since it's based off the Accord chassis . That's not a truck, as far as I'm concerned.
I could say that anything that doesn't have at least an 8-foot bed isn't a truck... but I think some would take offense to that. I'm sorry, but if I can't put two dirt bikes back there and close the tail gate.......
