Dead Battery Blues
Old Oct 17, 2005 | 07:36 PM
74fordtruck's Avatar
74fordtruck
Okay, so i got Bill's ammeter under there and I've been poking around. With the alternator totolly disconnected there was still a draw from the neg cable to the neg terminal. I know I'm not an expert with this equiptment, but when it just shows a 1 on the left side of the screen, it's maxed out or something isnt it?
I hit up the fuse box with the meter, and the only thing that's drawing is the cig lighter/fog light circut. It's a very small draw though, doesnt account for the huge draw from the battery. Oh, and the voltage regulator is part of the alternator, so there goes that idear.
Any other ideas are totally appreciated. THANKS!!!
Old Oct 17, 2005 | 09:18 PM
kspilkinton's Avatar
kspilkinton
Scott, WHAO!!!!
If you did the digital ammeter, with a large current draw you'd be replacing fuses in the meter right now (or could be buying Bill a new meter). When a digital is hooked in series with the circuit they usually have a 2-10amp max fused circuit rating. If this thing is drawing enough current to kill a battery that fast, it's going to pull more than a few amps. A "clamp on" ammeter is your best bet for a large draw.
Think about this... you'd have to take a cable off the batery and substitute the meters (tiny) leads as the jumper between the terminal and the battery cable. The leads aren't designed for this and neither is Bill's meter...
Remember, I recently checked the theory of large current through small wires...see the sig?
-Kerry
Old Oct 18, 2005 | 12:54 AM
74fordtruck
Sooo....what do you suggest? I put it on my truck's battery between the neg wire and the battery with the key off and got the same 'maxed out' response, and I know there's not much draw through that, just the radio. I'm pretty well stuck. Brooke wanted to take it to the mechanic first thing, but I figured I'd be able to do something. Hope I havent met my match, a DODGE!!!!!
Old Oct 18, 2005 | 11:50 PM
GregTruck's Avatar
GregTruck
Next time the car is going to sit for a few days go ahead and disconnect one of the battery cables. If you come back and the battery is dead then you KNOW that the battery is the problem. Simple process of elimination will do your work for you sometimes, or at least save you from other unnecessary guess work.
Batteries can be tricky sometimes in the problems they can cause. They can test good and be bad. In these great high tech times we live in many parts stores use the digital load tester which is limited in its capability to really test each cell. I said that wrong, it does not test each cell. Instead it tests the whole battery for ability to hold a pre determined voltage under load and then recovery time when the load is off.
When we used hydrometers we knew the specific gravity of each cell which told a lot more. The hydrometer used in conjunction with a hand held load tester was the way to go. Ahh the good old days!! Not so long ago
Old Oct 20, 2005 | 11:19 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Adjust the range of current setting on the meter to a higher setting. If for example you've got it set on 20mA and there's a 100mA draw, the meter is gonna show that 1 as you've noted; it won't read over that 20mA. If the current draw get's real ugly, you can shift the leads around on that meter and it will read 10 amps. So with this in mind, try the 200mA setting followed by the 10 amp setting. Also, remember to turn the meter to off when done to keep that internal bettery alive and the results from the meter accurate.
