Aerostar Ford Aerostar
94 outer cv joint removal??????
Old Oct 16, 2005 | 06:54 PM
99f350sd's Avatar
99f350sd
So how in the hell do you get the joint off. Surely not by banging on it as the directions say. has anyone figured this out. I need to rplace the darn boot and I'm Pissed off..
Thanks
Dick
Old Oct 16, 2005 | 07:29 PM
xuzme720's Avatar
xuzme720
the CD specs out some specialized tool #'s, but it sort-of looks like a puller of some kind. betting a steering wheel puller would work if you can find/make a suitable adapter for the hub to attach it. DON'T just hit it, ford CD says specifically not to.look here for the CD.
Old Oct 16, 2005 | 07:52 PM
99f350sd's Avatar
99f350sd
I think thats for knocking the axle through the bearing. I have the axle on the bench in a vise. the outer joint spposed to come off by hitting it with a soft hammer but no go.
Old Oct 16, 2005 | 07:53 PM
ken1mod's Avatar
ken1mod
Dear Xuzeme,
I am downloading the cd now, thank you very much for posting the site. Is it more or less a repair manual?
Ken
Old Oct 16, 2005 | 07:58 PM
xuzme720's Avatar
xuzme720
ah..ok. where did those instructions come from? that's a first for me. BTW the puller I mentioned was to seperate the outboard CV stub shaft. an assumption on my part, thought that's where you were.
Old Oct 16, 2005 | 07:59 PM
xuzme720's Avatar
xuzme720
Originally Posted by ken1mod
Dear Xuzeme,
Ken
it's the ford technical manual.
Old Oct 16, 2005 | 08:18 PM
99f350sd's Avatar
99f350sd
The directions came with the boot. Can you copy and paste a pic of the puller maybe..Thanks for your help..Of all the threads I've read and it was all of them the only puller I saw was the one that pushed in on the shaft to separate it from the wheel bearing. You are the first person who may have an answer.
Dick
Old Oct 16, 2005 | 08:29 PM
xuzme720's Avatar
xuzme720
unfortunately no....my account isn't active. the link I gave in a previous post is to the full ford technical CD's. they should be a great help, as that's where I got my info from.
sorry I couldn't help more, hope this helps some.
Old Oct 16, 2005 | 08:31 PM
99f350sd's Avatar
99f350sd
I'm looking in my 99 windstar cd now.
Thanks I have dial up.
Dick
Old Oct 16, 2005 | 08:41 PM
99f350sd's Avatar
99f350sd
Anyone have a 94 cd they can lookup outer halfshaft cv removal.???
Old Oct 16, 2005 | 08:53 PM
xuzme720's Avatar
xuzme720
looking more thoroughly through this, it shows no other removal technique. in fact it's showing that the outer joint can't be removed from the half shaft. the inner joint can be and should be sufficient to replace boots. let me know if this works or is workable for you. dinners over and the wife will want the comp soon.
Old Oct 16, 2005 | 09:26 PM
96_4wdr's Avatar
96_4wdr
secound that Xuzme,
i don't think nor do i find anything on removing the outer cv from half shaft, have replaced mine as whole unit with boot, etc.
Old Oct 16, 2005 | 10:00 PM
koalamazed's Avatar
koalamazed
replacing the joints are such a pain, i have always just got a whole new axle assembly. by the time you go through the hassle of removing the joint and regreasing and rebooting, you would have wished you just paid the extra 10 or 20 bucks for the whole deal. hell, just not having to deal with the grease is worth the 20 bucks. lol
Old Oct 16, 2005 | 10:38 PM
99f350sd's Avatar
99f350sd
The boot cost me less than 20 bucks. Comes with greese why would I want to do anything else? On my 99 cd it says to use a brass drift to knock it off. Its in a different area than the axle install. You have to go back to the menu and choose front drive half shafts then assembly and dissassembly.At least on mine CD. I will get it off.
Its gotta be replacable,the joint and the boot.
Dick
Old Oct 16, 2005 | 10:39 PM
xuzme720's Avatar
xuzme720
the boot is. the outboard CV joint is part of the half shaft. windstar is a different animal.
