cut out
Thank you, David
How do I locate and test the tach sensor?
Thank you for the reply, David
To set to specs:
With a warm engine and the idle speed set to your engine specs probably 650 in drive (curb idle).
Now with key on engine off. First connect the negative lead of a volt meter to the negative battery post, then place a paperclip straightened to slide up the side of the center wire for a good contact, touch the positive lead to the paperclip. Electrical connector must beconnected to the FIPL.
If your FIPL requires resetting loosen the small torx screws and attempt to attain the correct setting. You can loosen the large bolts on the bracket if necessary but try to retain the centering on the FIPL/blade.
Your trying to get closed throttle voltage: 1.1 V, wide open throttle voltage: minimum of 3.8 V but not more than 4.3 V.
If you can attain those #s then tighten the screws/bolts and ensure the voltage is at the correct setting after tightening. You can also do a slow sweep of the fuel lever from idle to WOT to see if there are any blanc (dead) spots, much easier with a really $$$ meter with capture mode. If you still find there are hard shifts or very soft slippery shifts you can adjust to suit your driving but be warned slippery shifts will burn the trans up.
Tach info.........
The dead tach should send the automatic trans into a "failure management mode" (limp mode) with harsh engagements and firm shift feel, and an abnormal shift schedule.
Replace the tach sender on the oil fill housing a big 1" nut with 2 wires. Ford only part Engine RPM sensor E5TZ-17B384-A about $50. You can remove and clean it but usually changed later too. You can test it too, hold it in the air away from ferrous metal, using an ohm meter lead on each wire you need DC resistance between 2000-3000 ohms.
