1978 - 1996 Big Bronco
'79 Bronco stalling
Old Oct 16, 2005 | 01:21 PM
nytreeman's Avatar
nytreeman
Exclamation '79 Bronco stalling
79 Bronco giving me a headache.with a C-6 ,400 m rebuilt approx.1500 miles ago bored 30 over new pistons and bearings,towing cam w/a Holley 4 v and edelbrock intake and all emissions removed.Engine runs fairly well just sitting at idle but is has had for a while some valve lifter noise when driving under slight load but none on highway or even at a hard load if I get on it more.But now the main problem is that it wants to stall . Seems to run fine until it warms then stalls at stop signs and sometimes as soon as its in gear have to feather the gas just to keep it idleing .But will start right back up and when driving down the road has plenty of power and takes the gas fine.I have a clear fuel filter at the carb and even when it stalls its full of gas and cant find any vacuum leaks tried re-timing and carb adjustments and doesnt seem to matter.It had been a mudder and has spent some serious time being hammered on and been in the air alot.Was wondering if maybe the harmonic balancer could have spun?would that cause this?any help would be appreciated -thanks
Old Oct 16, 2005 | 09:14 PM
MBBFord's Avatar
MBBFord
It almost sounds like a vacume leak, but with some of your descriptions it seems to point away from that.
Hope someone else can help, but sounds like a great rig.
Old Oct 17, 2005 | 01:03 PM
nytreeman's Avatar
nytreeman
I thought is was vacuum at first but so far havent found any leaks
Old Oct 17, 2005 | 02:55 PM
sideout2's Avatar
sideout2
Are you still running the stock ignition? With the emissions removed you need to recurve your distributor. That is probably the valve train noise you are hearing. Try advancing the timing and see if that helps, but you should address the issue. Post this is the 335 series forum in the engine section. Those guys really know their stuff.
Old Oct 18, 2005 | 07:34 AM
nytreeman's Avatar
nytreeman
Exclamation Bronco stalls in gear
I have a 79 Bronco which is giving me a headache.with a C-6 ,400 m rebuilt approx.1500 miles ago bored 30 over new pistons and bearings,towing cam w/a Holley 4 v and edelbrock intake and all emissions removed.Engine runs fairly well just sitting at idle but is has had for a while some valve lifter noise when driving under slight load but none on highway or even at a hard load if I get on it more.But now the main problem is that it wants to stall . Seems to run fine until it warms then stalls at stop signs and sometimes as soon as its in gear have to feather the gas just to keep it idleing .But will start right back up and when driving down the road has plenty of power and takes the gas fine.I have a clear fuel filter at the carb and even when it stalls its full of gas and cant find any vacuum leaks tried re-timing and carb adjustments and doesnt seem to matter.It had been a mudder and has spent some serious time being hammered on and been in the air alot.Was wondering if maybe the harmonic balancer could have spun? would that cause this?any help would be appreciated -thanks
Old Oct 18, 2005 | 07:37 AM
nytreeman's Avatar
nytreeman
Yes it is the stock distibuter,I have advanced it and it helps a little bit but still wants to stall and still has the valve noise.I'll try posting in the engine forum -
thanks
Old Oct 18, 2005 | 07:49 AM
Torque1st's Avatar
Torque1st
Posting Legend
Plug the vacuum line to the power brake booster and see if it still stalls.
Please do not cross post.
Old Oct 18, 2005 | 02:29 PM
nytreeman's Avatar
nytreeman
yes I already tried it without the booster and the line plugged,it didnt matter
pitcherd
Jun 9, 2013 09:09 AM
ford2002f150
1997 - 2003 F150
Mar 13, 2011 12:04 AM
old uhaul
Oct 21, 2010 02:30 PM
raycgl
Feb 22, 2007 10:11 AM
satx77stepside
Sep 22, 2001 06:10 PM
