I have a little issue with brakes, anyone offer some assistance?
Brake pedal goes all the way to the floor. Replaced master cyclinger, bleed brakes all the way around and still pressure on the pedal?
Thank you
AARON
Tim
I found out it was the pressure differential valve, located on the drivers side frame
I blead that and then blead the 4 all the way around and the brakes are tight ! Best they have ever been.
Problem solved
Thank you
Aaron
