help it dies at idle
Old Oct 15, 2005 | 05:36 PM
lastminute's Avatar
lastminute
Red face help it dies at idle
I'v got a 95 350 cc/lb auto it has a new fuel filter, new thermostat(125 at the block after a long run and 96 on the return line) now it at least comes up to operating temp. The problem is at idle when backing or moving in a parking lot it will just die. it restarts quick and easy. also I don't think my mpg is up where it should be. Any body ave a good idea what to look at?????
lastminute
Old Oct 15, 2005 | 07:05 PM
1997F-350's Avatar
1997F-350
take a reading on the schraeder valve. see what kinda fuel psi you got. a cheapo tire gauge will work. its on the side of the fuel bowl.
Old Oct 15, 2005 | 08:11 PM
ltfox's Avatar
ltfox
Possibly cam sensor??
Old Oct 15, 2005 | 09:10 PM
lastminute's Avatar
lastminute
What should the pressure level be at? I will check it out, just got the area cleaned and saw the valve stem and wondered what it was for.
Old Oct 15, 2005 | 10:43 PM
ltfox's Avatar
ltfox
40-50 lbs is normal.
Old Oct 16, 2005 | 12:19 AM
lastminute's Avatar
lastminute
Thanks I will check it out in daylight
Old Oct 16, 2005 | 06:32 PM
lastminute's Avatar
lastminute
I checked out the schraeder valve today and it appear to be a solid 60 psi, could it be and ICPsensor? some of the problems seem to be similar sounding to mstepchinski's post in the weird behavior thread
Old Oct 16, 2005 | 06:37 PM
ltfox's Avatar
ltfox
Unplug the ICP sensor. It will give a CEL(check engine light) but ignore it and see if it runs better. Unplugged the ICP goes into a default mode.
Old Oct 16, 2005 | 07:11 PM
barebackjake's Avatar
barebackjake
could be the ipr is plugged up or needs to be rebuilt. so it only does it when your moving around at idle? does it stay running when you start it and just get going? one way to see if your ipr is somewhat working is to unplug it while its running. if the truck stalls atleast the solinoid is somewhat working. if it stays running the ipr needs to be replaced.
Old Oct 17, 2005 | 10:57 PM
lastminute's Avatar
lastminute
It dies when I stop to back into a parking spot, or sometimes when I stop for a turn. seems to be mostly if I let the rpm's drop to fast, if I feather the throttle down I can keep it running. Also I have notice a short miss at speed and some times it just doesnt hold the rpms steady (kinda like its hickuping or something) what ever the problem is I think it is negatively affecting my milage.
Old Oct 18, 2005 | 10:26 AM
barebackjake
sounds like a high pressure oil problem. i would be looking at the ipr or injector orings.
Old Oct 23, 2005 | 05:02 AM
lastminute's Avatar
lastminute
well I finally got in to the dealer to have a scan done. Seems the the exhaust back pressure sensor was bad and the tube plugged. I tried to ream the tube but it was so plugged that I couldn't clean it so I replaced ti w/ a new one. I replaced the egbp sensor, and put on a qwick filter. it did die on me on my test run, but I have not had the computor cleare yet, I am currently trying to get hooked up w/ somewone that can clear and reset the computor, as I can't buy my own right now. [/I]broke from buyin the truck[I] will advise after the comp is cleared how it runs. "lastminute"
Old Oct 23, 2005 | 05:33 AM
1997F-350's Avatar
1997F-350
to clear your computer unhook your batteries and turn headlights on for 10 minutes or go to a parts store and have them clear codes with code reader for free.
Old Oct 23, 2005 | 09:55 AM
lastminute's Avatar
lastminute
thanks I will try that this after noon
Old Oct 28, 2005 | 12:13 AM
lastminute's Avatar
lastminute
Well It's finally running good. to days and it hasn't died. I put on the new egbp senso and tube but that did not help the problem I was having. I just bought the truck two weeks ago and am still getting maintainance items cleaned up as I have no idea when things were last performed. I went out Tuesday night and changed oil and oil filter "yuch" it was really black..filled up with rotella t, also changed out the air box for a qwick filter. Now when it is warm no blue haze and it has not died since. I guess that the dirty oil from "who knows how long" was not letting the injectors fire right......
Now time for a 3" down pipe...........
