Problem, can someone help?!?!
Old May 25, 2002 | 10:40 PM
Cowboy68's Avatar
Cowboy68
Hey all, I just bought my dream truck, it is a 1978 F-150 Ranger Lariat, i love it to death but I have two questions for ya. First it seems that when I push my accelerator down, the engine is playing catch up with the tranny, it almost feels like running a manual tranny at very low RPM does anyone knwo how to fix this or if it is normal. Second, my drivers side door almost seems to be loose, when I hit a bump in the road it bounces up (makes a loud thump) I was wondering if anyone knows how to fix the problem. Thanks for the help everyone.
Old May 25, 2002 | 11:09 PM
woppini's Avatar
woppini
The c6 tranny can start in 2nd gear, they call it a snow gear. If your linkage is misadjusted, you might be in 2nd, when it says drive. Also you might have bad modulator, or vacuum line going to it. Is your kick down rod connected? it goes to the carberetor to the tranny. As far as the door, the hinges might be worn and sagging. Check the striker pin on the cab for the plastic collar. If its missing, the door wont latch properly. JC whitney among other catalog places sells a new pin with the collar mounted
Old May 25, 2002 | 11:29 PM
Cowboy68's Avatar
Cowboy68
Thanks for the help, one more question, if my tranny is mis alligned, will this cause a problem fot the truck, or is it just a pain in the back side?
Old May 26, 2002 | 02:51 AM
woppini's Avatar
woppini
If you feel there maybe a problem, you should get it checked out by a good tranny shop. Its not good to have a slipping trans, or a 2nd gear start out all the time. Also check that this isnt an engine problem ,such as retarted timing or something
Old May 28, 2002 | 09:24 PM
masterbeavis's Avatar
masterbeavis
[updated:LAST EDITED ON 28-May-02 AT 10:25 PM (EST)]Check out your door latch, and see if your weather striping needs replacing. Those usually are the culprits for door problems.
Tony
'77 F250, 4X4 460 transplantee, "Flamer"
'74 F250. 460, "beater" now "1 dead ford"
'73 F250, "midnight auto" now a trailer for the flamer
Old May 28, 2002 | 10:45 PM
Jimbare's Avatar
Jimbare
all alone in the world
r1raven
Oct 17, 2014 05:56 PM
RoushFan00
2004 - 2008 F150
Feb 1, 2011 01:19 PM
dieselbogging
Sep 15, 2006 05:32 PM
polaris4x4ex
2004 - 2008 F150
Dec 5, 2004 08:53 PM
dolphins
2004 - 2008 F150
Sep 6, 2004 10:54 PM
