I just had my distributor recurved for the correct vac advance for my motor at Blue Oval in Denver. It turned out my distributor had a bad vac advance that wasn,t working at all. The fresh remanufactured one had a bad vac advance too. Rob found a used one off his shelf that worked then he reset the advance on it for my engine specs. Man what a big difference. If there's noone in your area might give him a call
