Dome LIght
Old Oct 14, 2005 | 09:58 PM
oldbluebronco's Avatar
oldbluebronco
Lightbulb Dome LIght
My Bothers 95 Dome Light doesn't work. What are the steps for troubles hooting. If A fuse is put in the slot it stays on constantly.
Old Oct 14, 2005 | 10:40 PM
pawpaw's Avatar
pawpaw
Look in the Miscellaneous section at the bottom of the "Technical" "Read First" thread, Ken has atop the main page on ths forum.
In there you'll find a lnk to many posts & discussions about what & where to use the "dome light/door ajar" fix. A wealth of other info there too.
Let us know how you do!!!!
Old Oct 14, 2005 | 10:57 PM
jimw411's Avatar
jimw411
Assume that the dimmer switch isn't turned all the way till it clicks, i would suspect the switch thats in the door latch. Ususally if it's the door switch the door ajar light on the dash stays on. If the switch is dirty and thats causing the problem i've heard of people spraying wd 40 or contact cleaner on it and fixing the problem.
Old Oct 16, 2005 | 09:10 AM
Crimedog54's Avatar
Crimedog54
Here's some ideas for you.
https://www.ford-trucks.com/forums/s....php?&t=327054
I use either wd40(which seems to be my universal fix for everything on this truck), or some contact cleaner. I wouldnt advise graphite or lock-ease because for some reason it made my problem worse.
Old Oct 16, 2005 | 01:00 PM
GeneB_45's Avatar
GeneB_45
I had the door ajar light problem, and the dome light satying on.
After hearing the wd 40 solution, I srayed the left door lock (as much as possible) with brake clean, and followed with electrical lubricant (CRC I believe).
Had the same problem again after a while.
I sprayed again.
Done deal.
I am guessing, with the cooler weather, I will need to go thriuygh the process again soon.
No big deal.
Gene
