Amsoil
Old Oct 14, 2005 | 04:30 PM
steelman's Avatar
steelman
Amsoil
On the 6.0, is any one using the amsoil in there powerstroke? How do u like it and how many miles between oil changes? What weight of oil do u use
Old Oct 14, 2005 | 06:32 PM
wb6anp's Avatar
wb6anp
I Have been using it I changed to amsoil at 5000 and changed it again at 10000 mi because my oil analyisis suggested that I change it due to high silicone levels. Am about to do another anylisis. I use amsoil 15W40. They have two versions synthetic and synthetic blend. I also use it in my wifes freestar and ahve done a analysis on it also, have not needed to change it since I put it in at 5000 mi now have 13000. Also get the fumoto valve it REALLY helps in changing the oil and taking samples.
Old Oct 14, 2005 | 06:35 PM
Bob Ayers's Avatar
Bob Ayers
Most of Amsoils oil products ARE NOT API certified. To keep a vehicle manufacturer's warranty valid, you must use an API certified oil. One other problem with Amsoil products, since it is a MLM company, the cost of their products is highly inflated!!!!
Old Oct 15, 2005 | 09:53 AM
firesoutmatt's Avatar
firesoutmatt
Bob Thanks for the info but thats not what he asked !!!! And your wrong on both accounts. Steelman I switched to Amsoil at my last oil change at 10k with 15w-40 diesel and plan to run it 5k with an oil sample . I ran it in my 01 7.3 for 43k miles with no problems . My mileage did improve about .5 mpg but havn't run it long enough in the 6.0 to know if its improved. Amsoil is a good oil and havn't had any problem running it in anything I've own.
Old Oct 15, 2005 | 10:01 AM
Bob Ayers's Avatar
Bob Ayers
I'm sorry, but I am correct on both accounts!!
Here is the API URL, showing the Amsoil oil products that ARE API certified:
http://eolcs.api.org/DisplayLicenseI...LicenseNo=0995
AND, Amsoil IS A MLM company!!!!
What is your affiliation with Amsoil?????
Old Oct 15, 2005 | 10:13 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
OK you guys know if it is about Amsoil...it gets locked...so
