I'm not a guru, but this is like the stuff I study in school (industrial controls). So, here's your tax dollars at work!
I found this info in my Haynes manual for '75-'76 truck:
1. With a two speed switch: GR/BK to washer pump.
Two speed with intermittent: GR/BK to washer pump, W/BK-power to governor and switch. These are the only wires with a black tracer.
2. O, R/BK, Y/R go to the accessory safety relay. Y/R is the control wire from the mode switch (AC, heat, defrost). The O and R/BK are the switched circuit. O is hot, R/BK is the power feed to the blower switch.
3. One is the R/BK in #2, the other runs parallel to the blower resistor. Diagram shows them joining with an orange(?) wire-power to the blower switch.
4. The only plain Brown wires on this diagram are associated with the running/marker lights.
Make sure you have adequate light, and take a few breaks when you work on stuff like this. It helps keep the smoke in.
thanks, yeah i dont wnat these wires getitng toasted when i got the truck it had a hacked harness and it shorted and toasted thre wiring thats why im in this pickle now, thanks though.
Yea im trying to rewire this truck I know where most every plug goes for the most part just a few here and there that has me stumped.Im getting there though ,hope to have it all wired up soon.
thanks, mine has more plugs though, its weird, ive seen other trucks but my truck had more plugs and wiring than others ive seen.ill gt it figured out though .
