1978 - 1996 Big Bronco
Snow plow setup
Old Oct 14, 2005 | 12:29 PM
MichSandSquid's Avatar
MichSandSquid
Snow plow setup
I'm looking at getting a 2nd Bronco to replace the one I have now (I'm north of the rust belt) and I want to set it up for my snow plow. My question is should I go with a lift kit to get the frame up a little more with weight of the snow plow on it or just stick with the heavy duty springs & shocks on the front end?
Old Oct 14, 2005 | 01:43 PM
greystreak92's Avatar
greystreak92
You might consider a leveling kit to go with the heavy duty spring/shock setup. It will help considering The Bronco sits just a little nose heavy in stock form and adding a couple hundred pounds will only make it worse. The kit usually consists of a pair of 1.5-2" polyurethane spacers that go under the front coil springs and a pair of longer studs to hold the spring and spacer down.
bigwin56f100
2004 - 2008 F150
Apr 16, 2014 09:31 PM
bigwin56f100
Ohio Chapter
13
Mar 6, 2014 09:37 AM
Caleb H
General Automotive Discussion
22
Dec 18, 2011 07:05 PM
stugpanzer
Dec 13, 2008 09:27 AM
