How do you remove the driver's side panel in order to replace the mirror? I've removed the clips and screws but it doesn't want to lift up. Am I missing something?
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
I have a 05' STX Scab and just installed some Power windows, door locks, and new speakers(front and rear). I do not know if the door panels are the same but I will tell you what I did to remove it...
1 screw located beneath the arm rest
2 screws on the bottom
2 screws behind the door handle access panel
1 screw behind window crank (im sure ya dont have this)
I then removed the speaker cover and took out the speaker. You then have to remove the rubber gasket on the bottom of the speaker cutout and then remove the bottom 2 nylon screw flanges which the speaker mounts on. This should free the door up from any obstructions and lift right out. Hope this helps ya.
