Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
hey #######!!!!!!!!!!
Old Jun 4, 2001 | 11:41 AM
fordy's Avatar
fordy
Hey Clatter! What make and model of trucks have you owned in the past? What did and did you not like about them? What would make you turn to (un)Generous Motors?
What makes you feel comfortable with a diesel engine with aluminum parts?
Fordy
1978 F-250
Old Jun 4, 2001 | 11:53 AM
Guest
Posts: n/a
[font size="1" color="#FF0000"]LAST EDITED ON 04-Jun-01 AT 01:35 PM (EST)[/font][p][font size="1" color="#FF0000"]LAST EDITED ON 04-Jun-01 AT 01:30 PM (EST)[/font]
[font size="1" color="#FF0000"]LAST EDITED ON 04-Jun-01 AT 01:06 PM (EST)[/font]
Ford pickup safety 'poor'.
Most popular pickup truck's crash safety 'bad as it gets'.
http://cnnfn.cnn.com/2001/06/04/home_auto/pickups_crash/
I've owned ...
1980 F150
4.9 Straight six... Couldn't get rid of the pre-ignition
Brakes... One side kept wearing pre-maturely into the rotor. Replaced everything including caliper assy and it still kept doing it
Rear... axle seals had to be caulked to prevent them from leaking
Interior... Fell apart... literally
1984 F150
This was an interim vehicle between Chevy trucks. I had to remind myself why I love Chevies with that one. I only got between 6 and 8 mpg with a 302. Power steering was so powerful, you couldn't feel the raod at all. The twin I-beam IFS didn't let me steer. It steered for me. If the road was rutted good enough, I didn't have to put my hands on the wheel.
No Fords since I bought my first Chevy in 1990. I actually was at a Ford dealership looking for a used Ford pickup when I ran into a deal I couldn't pass up. I liked the Chevy K1500 Stepside so much that I ended up Pro Chevy. Can you imagine that?
Here's a list of a few of the vehicles I've wrecked, uh I mean, owned.
http://uscom.com/~hoot/cars/cars.htm
As far as aluminum parts are concerned...
I admit.... I am a Guinea Pig
2001 GMC Crew Cab/ SB 4x4 Duramax/Allison
Old Jun 4, 2001 | 01:03 PM
Guest
Posts: n/a
GM tested the Duramax on a full load durability test that ran 2500 hours, about twice as long as it tested the 6.5TD and four times longer than it's gasoline engines.
The Duramax passed one of the most severe thermal shock tests in the industry.
With the thermostat removed, the engine is run on a dyno at full load at normal operating temperature. By switching a special valve in the plumbing that supplies coolant to the engine, cold water can be fed directly into the cooling system. This is a brutal test for any engine and if a head is going to warp and blow it's gaskets, this test will make it happen. Several engines were sucessfully tested on both cycles and GM is confident the Duramax is up to the task.
I hope this helps.
Old Jun 4, 2001 | 02:23 PM
iknowitall's Avatar
iknowitall
i have driven Duramax before.
they spin to many rpm
they have almost no get up and go
they do now have the power Gm says they do
I tryed pulling my friends trailer with it
had to put the gas down half way in first to move it
when I just tap the gas in the ford ( diesel )
I just don't like anything about them
they don't sound nice like the cummins or the ford
they are jap which makes them cra.p
Old Jun 4, 2001 | 10:31 PM
fordy's Avatar
fordy
Hey, the cheby/gm is still marginal & poor in 2 of the 3 categorys. They are not as perfect as you make them sound.
Fordy
Old Jun 5, 2001 | 09:44 PM
bigfordman70's Avatar
bigfordman70
Whats with the #######2?
BFM
Old Jun 11, 2001 | 12:56 PM
Pastmaster's Avatar
Pastmaster
Since I have family who owns a Duramax, and has let me drive it a bit. 25miles or so. I have to stick up for it. I don't know what you consider no power, but the GMC Crewcab 4x4 373 I drove had excellent getup and go. Beats the poop out of the ISB cummins he had in his 96 Dodge. I'm not sure that it can out-tow either of the other diesels, but it can outrun one when unloaded stock. They are fast and quiet, noise is an issue that some people like and don't like, but at least you don't have to put the radio at the highest volume like in a Dodge.
Ford has competition now that they only had with Dodge. But GM better stay on their feet, because the new 6.0L PSD2 is sure going to be a bit ahead of the 2001 D's.
Old Jun 11, 2001 | 09:46 PM
gamehunter's Avatar
gamehunter
fordi3s3l
Apr 12, 2014 09:06 AM
Greywolf
Sep 26, 2011 09:04 PM
Greywolf
32
Apr 25, 2006 07:29 PM
fordy
Dec 1, 2002 09:38 PM
fordy
Oct 28, 2002 01:48 AM
