Duraspark module died.
Old May 28, 2002 | 07:34 PM
76supercab's Avatar
76supercab
I took the truck into work today cause it was the vehicle that had the good battery in it. Got there and someone mentioned my white shirt and how it would get dirty if I worked in it. I snidely replied I didn't plan on working today. Oops. Went out to the truck to go home and it wouldn't start. Getting gas, motor turning, rotor turning, NO Fire. Hmmmmmm. Put a volt meter on it have voltage at coil but coil not firing. Called my wife and went to get an ignition module. Slapped it in while my wife left her car running. Jumped into the truck and it hit on the first rev. I was stoked.
Now I need to go get another one of those modules to keep under the seat. They had 2 choices $23 or $75. Since I didn't know for sure it was the box I got the cheap one.
Old May 28, 2002 | 09:56 PM
tetraruby's Avatar
tetraruby
I just switched to MSD for a few reasons, but your experience today is one of them (+ my truck runs really smooth now too).
Old May 29, 2002 | 10:54 AM
dfisher1's Avatar
dfisher1
All,
I have had many 73-79s. I've had some dura sparks go bad on me. The ignition system has always worked well when it worked. I find the system to be dependable and adequate for street use and even some mild track work. The after market system don't grow on trees and don't work much better for day to day use. If I loose a MSD, it will cost me $750 bucks to replace it. Does that make sense in an old pickup?
KingFisher
Old May 29, 2002 | 12:19 PM
hawkrod's Avatar
hawkrod
i find that the earlier durasparks do have a higher failure rate but with modern technology the modules have a much better rate (how old was the module that died?) i always convert my early duraspark to blue plug duraspark II and i have never had a failure. if an MSD dies in a daily driver i can't run down and get replacement parts at kragen. MSD is great for the specialty vehicle but for pure driveability and maintenance i would stick with stock. and as far as performance goes, jacobs electronics says the duraspark is good to 8K and hard to beat. they used to have an easy conversion for them for racing. hawkrod
Old May 29, 2002 | 02:16 PM
TheWiz427's Avatar
TheWiz427
>All,
>KingFisher
You paid $750 for your MSD i only paid $175 for mine?
Wiz
Old May 30, 2002 | 12:50 PM
Gobstopper's Avatar
Gobstopper
What are the ramifications of running the truck with no ignition module as I presently am? I am waiting to afford myself a Mallory Hyfire, but for now I tossed the stock ignition module and just have the coil connected to 12 volts (with key on of course) through a ballast.
BOB
Old May 30, 2002 | 09:26 PM
tellico racing's Avatar
tellico racing
>BOB
how could that be possible? it runs? i must be missing something
Old May 30, 2002 | 10:46 PM
Torque1st's Avatar
Torque1st
Posting Legend
Keep the stock Duraspark II ignition module.
Was the ignition module that failed an OEM unit or aftermarket? The aftermarket units seem to have a much higher failure rate. The key to those units or any electronics under the hood is keeping them cool. Ford has a TSB out that calls for putting 1/4" high spacers under the module to allow air flow on the back side to enhance cooling. Look on ebay, every once in a while you will see a genuine OEM Motorcraft ignition module come up for auction. Most sellers on ebay claim OEM but they are aftermarket units.
Another source of good modules is the junkyard. Again look for motorcraft modules then take them to a parts store that has a tester to see if it is good.
An engine won't run without some sort of current interrupter [either points or a module] to fire the coil. The points or ignition module is on the ground side of the coil.
Old May 31, 2002 | 10:30 AM
Gobstopper's Avatar
Gobstopper
Are we talking about a silver metalic box, about 4 inches by 4 inches and about an inch to 1-1/2 inches thick ?
Mine is gone. Engine starts and runs fine.
12 volts hot when key on connected to Mallory coil ballast connected to Mallory coil connected to Mallory Unilite distributor.
Bob
Old May 31, 2002 | 10:52 AM
BB's Avatar
BB
The Mallory Unilite dizzy is a stand-alone unit without a separate box, I run one on my truck too, hasn’t skipped a beat in over 9 years.
Barry
Old May 31, 2002 | 11:19 AM
Torque1st's Avatar
Torque1st
Posting Legend
As I said, you have to have some sort of current interrupter to fire the coil.
The Mallory just has it internal to the distributor, like electronic "points".
The Mallory and a stock distributor are different animals, apples to oranges comparison, different configuration.
There are many different types of ignition systems. The Davis DUI has everything mounted in the distributor. All you have to do with them is run +12 hot off the ignition switch, no ballast resistor.
A stock OEM type ignition system will frequently have a "resistor wire" built into the wiring harness for their ballast resistor. The ballast resistor function can also be performed in the module, depends upon the system.
There have been some recent dyno tests that show the OEM systems often outperform the aftermarket ignition systems up to ~6000 rpm. In a stock type daily driver you don't see that kind of rpm's.
To get back to 76's problem...
Stick with the OEM Duraspark II (blue grommet) and distributor system for a daily driver, you can get parts anywhere. Put 1/4" spacers under the unit like Ford suggests. Keep your electronics cool, heat is their worst enemy.
Old May 31, 2002 | 11:41 AM
tetraruby's Avatar
tetraruby
