do i need mass air?
Old Oct 13, 2005 | 05:08 PM
RollinHi95's Avatar
RollinHi95
do i need mass air?
i'm gonna start building a new motor for my truck probably next week. i'm gonna bump up the power with a new, slightly bigger cam, gt-40 heads, and an edelbrock intake. my question is will i need to use a mass air conversion to support my mods? i might even bump up the compression a little but not enough to keep from running 87 octane gas and i don't know the compression my factory motor has. its a '93 351.
Old Oct 13, 2005 | 07:33 PM
Blurry94's Avatar
Blurry94
The cam will play a large factory in wether you need to do the swap. If you looking for that "lopey" idle then you'll need to start looking for some mass air parts or a complete kit.
Old Oct 14, 2005 | 10:01 AM
RollinHi95's Avatar
RollinHi95
no, the cam i'm gonna get will probably idle like a stocker. its a comp 4x4 extreme. i can't remember the exact specs buts it got a real low duration and the lift is under .500.
Old Oct 14, 2005 | 11:26 AM
4x4 ext.'s Avatar
4x4 ext.
Look into MEGA SQUIRT before you make alll the desitions on the motor. It works with speed density and for the price its cheaper than converting to mass air. Its capable of 1000hp with speed density and its arround 200 bucks. I just finished my motor. 9.5:1 ,,, world product heads X303 cam ... once I converted to mass air I thought it would work but was wrong. It worked beter than SD but there were still issuess. Like an adjustable fuel regulator to drop the pressure on the injectors when I switched to 24#. Mega Squirt would have been a much cheaper way to go and the posibilities and mods are way more extreame. Make sure your lobe seperation on that cam is 114 and under .220 @ .050 ,,,,.500 lift. everything else should be ok
Old Oct 14, 2005 | 12:09 PM
Blurry94's Avatar
Blurry94
So you did a boat load of mods and then installed larger injectors, without a chip??? I can see why it didn't work then. I ran 42's with a mass air boosted setup and it idled like stock after I made some tuning changes.
Old Oct 14, 2005 | 03:10 PM
RollinHi95's Avatar
RollinHi95
where can i get the mega squirt? i'm not to sure on the lobe seperation i think its under 114 and the duration at .050 is 20? something with about a .480 lift. i can't remeber the exact specs and i'm too lazy to look it up lol.
Old Oct 14, 2005 | 03:22 PM
shmoozo's Avatar
shmoozo
Check out the following web site for more info on that sort of thing.
MegaSquirt EFI forums
Old Oct 14, 2005 | 03:41 PM
4x4 ext.'s Avatar
4x4 ext.
My truck runs nice without a chip only had to do the regulator. I want to chip it but not sure who to contact on a custom chip
Old Oct 14, 2005 | 04:31 PM
Blurry94's Avatar
Blurry94
A regulator like that is just a band-aid on a mass air system.
An SCT dealer can tune almost all EEC controled Ford vehicles on the road today.
Old Oct 17, 2005 | 05:19 PM
RollinHi95's Avatar
RollinHi95
i found this cam on comp cams website. would that work pretty good.
http://www.compcams.com/Technical/Search/CamDetails.asp?PartNumber=35-255-5
Ford 351W Computer Controlled XE254H Cam
DESCRIPTION:
HYDRAULIC-E.F.I. Speed Density, works with stock computer. Very strong torque, Excellent mileage, good idle quality.
Old Oct 17, 2005 | 05:43 PM
4x4 ext.'s Avatar
4x4 ext.
oh yea that cam would be fine. Probly be fine with speed density.Who would I contact on to program my computer.
Old Oct 17, 2005 | 06:52 PM
quaddriver's Avatar
quaddriver
From Charles Probst:
You need a mass air conversion to be able to run any major engine mods.
that said,
yes, you need mass air. No longer in production, NOS is selling for $630 right now. I did mine last summer as prep for my 347 (which I just got back from being balanced)
If you are running under .500, the GT40 heads are not much better than the E7TE's. Either prop up the cam some more (you dont have to go '303' - ie. roller) or run GT40P heads (which add the fun of locating headers)
the problem with running a chip, which I DO NOT recommend is that the fixed fuel map is just that - fixed for popular combinations, unless you are sitting there with a power programmer whilst on the dyno, it will work worse than it will work better.
Old Oct 17, 2005 | 07:14 PM
Blurry94's Avatar
Blurry94
DESCRIPTION:
I believe a few of the GEN 1 L guys are having problems with that cam...mainly wiping cam lobes.
Old Oct 17, 2005 | 07:21 PM
Blurry94's Avatar
Blurry94
You need a mass air conversion to be able to run any major engine mods...
...the problem with running a chip, which I DO NOT recommend is that the fixed fuel map is just that - fixed for popular combinations, unless you are sitting there with a power programmer whilst on the dyno, it will work worse than it will work better.
Speed density CAN be tuned to work with many bolt-ons: heads, cam, RR's, and dare I say it nitrous and/or a blower.
The cam selection will be limited, but that isn't anything a custom grind can't take care of, and it's still cheaper than a MA conversion, that will still need aftermarket tuning to dial it in with aftermarket parts.
Old Oct 17, 2005 | 07:27 PM
quaddriver's Avatar
quaddriver
But very few people have the ability to remap a fuel curve. Unless you buy one of the popular combos....for the price of a chip, and its two followons, you have spent more than the MA conversion. Thats why I recommend that the switch be made, then you can install whatever you feel like. The only common issue is the injector ratings
