Lost my smoothness
Old Oct 13, 2005 | 05:01 PM
Medic 66's Avatar
Medic 66
Lost my smoothness
Tonight I noticed a tinest change in sound of the truck at idle like it is idling up and down just a smidgen...looked at the tach and idles from 674 to 681....all summer stayed steady at 680rpm's during idle. No changes except 3 tanks without my DK or anything else for that matter. What would be the cause?
99 7.3 PSD
Old Oct 13, 2005 | 05:54 PM
Kwikkordead's Avatar
Kwikkordead
I would start by putting some DK back in and see what happens.
Old Oct 14, 2005 | 12:29 AM
kennedyford's Avatar
kennedyford
hey i was working on the ipr from the suggestions on a stream from one of kwikkordeads notes. If the ipr 3/4 nut is loose it wont run right.
Old Oct 14, 2005 | 01:35 PM
Medic 66's Avatar
Medic 66
I agree that Dk should be re-added to see if that is the problem....seems odd that an additive would casue that.....?
Old Oct 14, 2005 | 02:16 PM
1997F-350's Avatar
1997F-350
why does it seem odd? that stuff works wonders and will make your truck run very smooth and quiet along with cleaning and everything else it does.
an hpx line might help you out a little as far as the smoothness.
Old Oct 14, 2005 | 03:21 PM
slc10844's Avatar
slc10844
Maybe they are starting to use winter blend fuel in your area?
Old Oct 14, 2005 | 06:43 PM
Medic 66's Avatar
Medic 66
Funny you say that because after I posted, I had that thought when I was reading a little furtehr down the line...but none the less...need to return to the DK though for sure
Milly1219
2004 - 2008 F150
Jun 11, 2014 09:48 PM
LiftedBlackHD
May 15, 2014 06:00 AM
shark1979
23
May 14, 2013 06:42 PM
ramrodder007
Missouri Chapter
Apr 2, 2013 12:54 AM
dan b
Apr 3, 2010 08:01 PM
