Hello, 1977 f-150 302 with A/C. When the A/C is operating the truck has quite a shake to it. If you look at the compressor you can see the belt vibrating quite a bit. The belt is tight like it should be. On a recent trip to the pic a part I noticed that the other compressors had what seemed to be a balancer mounted onto the pulley. Is this required to stop the shake and vibrating belt? If so does it simply come off with the pulley. The compressor on my truck looks just like the ones at the pic a part, the only difference is that mine has no balancer, it is a remanufactured one.
You might have a warped internal rubber damper. If you can take the belt off and try spinning the a/c clutch by hand and watch it from the side view to see if it looks like an out of round revolution. That should be a quick and easy fix. Good luck with whatever the cause is.
OK, I put a picture in there under my 77. if you look right behind where the belt is all of the others that i saw had quite a large balancer there, or at least it looked like one.
there is no balancer on an a/c compressor. It could be an out of round or bent pulley anywhere on the engine, the A/C draws a lot of power so any imperfection in the belting could cause the vibration even if it isn't A/C related. Also check to make sure none of the A/C brackets are loose or cracked and make sure they are all there, most of the trucks had a bracket to the top of the compressor and I've seen alot of them discarded.
no thats not true, there is some type of a balancer on the other trucks at the pic a part. if you look at a normal compressor then you are correct, there is no balancer. however if you look at this style there is a large steel or cast peice that sits on the rear of the pulley, it is actualy much bigger around then the pulley. about twice the size. it has got to be a balancer, why eles would a big peice of metal be there? i will try to find a picture of one so you guys can see what i'm talking about.
NOPE, the piece that you think is a balancer is part of the spinning pulley, it does not connect to the crankshaft until you engage the clutch, therefore it can not be in the same place on the crank each time it engages. In order for it to be a balancer it would have to be permanently attached to the crankshaft of the compressor. And DEM is DA Facts
ok then, thanks for the info... now please tell me what that actually does? I have noticed that the peice we are talking about is on all of the origional a/c compressors at the pic a part, and also on the old f150's on ebay. it must serve a purpose if it's there, correct? my truck does not have one on it. should I be concerned about getting one? it looks like the same compressor and pulley, even has a place where this part looks as if it should go. does anyone know the purpose of this thing? Please understand that i'm just trying to figure out what this is for. thanks.
Mine is missing that piece and is shakes like crazy around town. It does smooth out on the highway. I'd like to hear what you find out. Mine appears to be a rebuilt unit and not the original.
ok guys you are thinking of the cast iron gigantic harmonic/dampener/ pulley. it was a factory piece on most trucks 73-79. so it appears you have the car pulley version which is cheaper and easier to find. to change them just loosen the belt remove the 1/2'' bolt screw in a 5/8'' bolt until it pops off then put on you new pulley and tighten the 1/2'' bolt down. reinstall the belt and your done.
Yep, That's the same for mine. It's a rebuilt unit that was put on the truck before I bought it. I'm thinking that it must smooth it out. I am going to pick one up from the pic a part sometime durring the next week I hope. If it works I will let you know.
If your going to just swap the pulley and clutch assy. make sure it doesn't rub on the field windings inside. Some of the aftermarket clutch kits have a different size field. After you bolt the pulley assy back on spin the pulley before you put the belt on and make sure it doesn't rub. They burn up fast when they rub.
