Build sheet received.. missing A/C?
Old Oct 13, 2005 | 03:43 AM
dakonthemountain's Avatar
dakonthemountain
Hi Guys,
I finally got Burt's buildsheet from Ford (took almost 2 months!) Pretty much everything on it I knew, except that old Brown Burt used to have White accent paint, and that he was made in the San Jose, CA plant on 4/2/77. Something puzzles me though. What was missing on the buildsheet is the factory A/C. Could this have been added at the dealer? Just curious..
Dak
Old Oct 13, 2005 | 03:53 AM
ford390gashog's Avatar
ford390gashog
request another build sheet i have 2 and both differ a little.
Old Oct 13, 2005 | 03:54 AM
ford390gashog
never mind what i said. i just looked at your gallery and your build sheet is right. because that is not a factory a/c system. it is add on.
Old Oct 13, 2005 | 12:25 PM
dakonthemountain
Really? and add on? Do you know then if this was a dealer add on? I really thought it was a factory ... did the factory A/C incorporate into the heater controls? (it does have a factory high output heater)
thanks for the info...
Old Oct 13, 2005 | 12:54 PM
Mil1ion's Avatar
Mil1ion
With vents on the dash .....That's factory A/C.
Yes there was a dealer A/C add-on as well.
Question !
Why didn't you turn those 2 pics before uploading ?
I can't turn my monitor 90* to view them
Old Oct 13, 2005 | 01:40 PM
73Custom's Avatar
73Custom
Nice pickup. Yours is considered 'dealer add on' air. The obvious difference is in the controls. Factory a/c is run by the same slide controls as the heat and defrost. Add on a/c has it's own set of controls for temp and fan. Since yours is 'dealer add on' it would've been built as a non a/c pickup, so the build sheet is correct.
Marty
Old Oct 13, 2005 | 04:11 PM
ford390gashog
yep those 2 ***** next to the middle vent tell me it was a dealer add on.
Old Oct 13, 2005 | 05:11 PM
dakonthemountain
Talking
Thanks for the replys guys. Dealer add on is fine with me! It works great, but the belt vibrates a lot when it is on. I am thinking off adding a tension adjuster to it to smooth it out a bit.
Dennis,
Sorry about the pictures! I have a laptop, so I don't have that problem. I have redone my gallery and added a listing, (from memory anyway!) of the upgrades, restoration, etc. I have done to date. Thanks again guys!
Dak
Old Oct 13, 2005 | 07:09 PM
nightman718's Avatar
nightman718
i would like to also get the build sheet for my 74 F250.. can you point me in the right direction on how to abtain the build sheet?
Thanks
Danny
Old Oct 13, 2005 | 07:24 PM
dakonthemountain
Ford390gashog listed this in the tips and tricks section: Got to ford.com then use the ask kate to request a build sheet.
I called Ford direct, but I can't find the number at this point... I do know I got it somewhere in the tips and tricks section of this site. The guys here are a wealth of information...
Dak
Old Oct 13, 2005 | 08:22 PM
nightman718
i went through all 5 pages of tips and tricks and didnt see anything about the build sheets
Old Oct 13, 2005 | 10:06 PM
gier-head's Avatar
gier-head
I'm in contact with Ford at this time on two VINs ( 78 F-350 and a 78 Bobcat ).
It's a long process. They have already "misfiled" my request once. They are trying
a second time currently. I have emailed and called them. They are glad to help. Just a matter of WHEN.
Try contacting the Ford Motor Company Customer Relationship Center at crcfmc@ford.com
Or contact them 1-800-392-3673. Monday through Friday 8am to 5:30pm EST.
Old Oct 13, 2005 | 10:39 PM
nightman718
Thanks for the number ill give ford a call
Old Oct 14, 2005 | 08:32 PM
gier-head's Avatar
gier-head
Oops. I was unaware of the email address posting policy.
Email me directly if you would like their email address.
Old Oct 18, 2005 | 06:58 PM
dakonthemountain
Ok nightman718, I finally found the info I used for the buildsheet.... Sorry for the delay! I was out of town until last night:
Ford Motor Company
customer Assistance Center
800-232-5952 ask for the Research Unit Representative in the Customer Relationship Center
Or...
Write to Customer Assistance Center
16800 Executive Plaza Drive
P.O. Box 6248
Dearborn, Michigan 48126
Credit for this info goes to Quadiquizm...
good luck!
Dak
