1976 Project
Old Oct 12, 2005 | 09:58 PM
coorslightkid22's Avatar
coorslightkid22
1976 Project
hey i just joined hoping someone here would have some ideas for me. i have lifted a wide variety of different vehicles, but this old ford is mine and i will be doing this in my own garage . i want some ten inch springs. but are hard to find for less then a grand..... anybody have any connections?????
chris
Old Oct 12, 2005 | 10:16 PM
MBBFord's Avatar
MBBFord
What size tires are you planing on putting on your truck, and what is it? F-150 250 what?
Old Oct 13, 2005 | 06:03 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
chris
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 14, 2005 | 10:02 AM
1975Ford's Avatar
1975Ford
Welcome to the best club around.
I have lifted a few of the 67-79 Ford F100 & F150 truck.
I personally believe a 10" of lift is a very high for the coil front suspension. Not to mention the angle of the front drive shaft to front axle.
A 4" to 6" would make a more suitable 4x4 for offroading purposes.
My neighbor lifted is 78 Ford Bronco about 10" by unbolting the front coil spring towers and bolting the towers lower and then installed a 6" inch lift coil spring to increase the height of the front end.
Old Oct 15, 2005 | 10:39 AM
hotroddually's Avatar
hotroddually
welcome to FTE! is your truck f100, f150, f250? what kind of springs you need depends on if its 1/2 ton or 3/4 ton. also,if you want that much lift, your going to need more than just springs.steering componants,brake lines,longer drive shafts,body lift may-be,not to mention shimms to correct your pinion angles on both your diffs.lifting properly and safely is not a good place to go cheap,you will only regret it later when you have hadling and stability problems. just my opinion,-billy
Last edited by hotroddually; Oct 15, 2005 at 10:41 AM. Reason: forgot to greet the new guy
Greywolf
Oct 13, 2010 06:38 PM
JamesMitchell
2004 - 2008 F150
May 3, 2010 01:51 AM
Bob at warsaw
Apr 13, 2008 10:42 PM
JohnAW
22
May 6, 2006 11:20 PM
