Ticking time bomb?
Old Jan 17, 2001 | 09:48 PM
400HP794x4's Avatar
400HP794x4
Ticking time bomb?
Old May 29, 2002 | 11:19 AM
adbradley's Avatar
adbradley
Ticking time bomb?
My 1976 F-150 (300 6 cyl) has started ticking and it does not go away, even after it is warmed up. It is definitely coming from the head, but is it the valves or the lifters? Is there any way to adjust valve lash and would this help anyway? Gotta replace the valve cover gasket so I thought it would be a good time to investigate this little noise. Thanks...
Old May 29, 2002 | 01:11 PM
beartracks's Avatar
beartracks
Ticking time bomb?
I'm pretty sure those are adjustable but wait for someone who know's for sure to tell you the proceedure.
Bear
Old May 29, 2002 | 04:34 PM
Mil1ion's Avatar
Mil1ion
Ticking time bomb?
I'd say it was a combination of Rocker Arms & Pushrods.
[b][i][font color=red]Dennis[/font][i][b]
[font color=red]Calgary,Alberta,Canada[/font]
[link:www.ford-trucks.com/guidelines.html|FTE Moderator]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=green] Truck Data Plate Info
[/font
http://www.clubfte.com/users/mil1ion/FordTruckCodes.html
[font color=red]If New Ford Parts Is What You're Cravin',
Then Buy Them HERE,At Motorhaven![/font]
http://www.clubfte.com/users/mil1ion/Mil1ion.html
[font color=red]
Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
[/font]
Old May 29, 2002 | 09:02 PM
Vampiro's Avatar
Vampiro
Ticking time bomb?
my 300 6 has a ticking sound only when cold. i was told to put a part on the oil filetr to stop that. i haven't been able to purchase it yet
i agree with dennis. pushrods or rocker arms
Old May 29, 2002 | 10:44 PM
TKONO's Avatar
TKONO
Ticking time bomb?
How is your oil pressure? The 300's were bad about not oiling the upper end when the oil pressure got low. When you take the valve cover off, put some rags around the top of the head and start the engine. If oil goes everywhere, you don't have an oiling problem. If not, check each rocker arm and see if oil is seeping out the top. If not you might be able to put in a high volume pump and cure it for a while.
John
Old May 29, 2002 | 10:59 PM
gray79f250's Avatar
gray79f250
Ticking time bomb?
The lifters are pretty easy to adjust if you have good oil flow. But if its real loud its probably a bad lifter. Luckily lifters are a snap to change on a 300 anyway and dont cost much either. Let us know how you make out when the valve covers off. If the engine is really slugged up I've had great luck running marvel mystery oil to free up stuck lifters.
Good Luck Andy
Old Jun 1, 2002 | 09:25 PM
jeffreysw's Avatar
jeffreysw
Ticking time bomb?
You can also check the oiling by pulling the distributor and spinning the oil pump with a drill.
Old Jun 2, 2002 | 06:13 PM
ford4life69's Avatar
ford4life69
Ticking time bomb?
I'm no mechanic but I have a friend who had a 300 6 that knocked and "ticked" for over a year before he finally threw a rod out the bottom of the engine one day going to college (he's in auto tech.) I have had 2 300 6's and one of them ticked constantly and I was told it was the wrist pins. That one would still run if I put a new egr valve and carb on it but it would still tick until finally it blew up too I imagine. The other 300 6 just got brand new timing gears and was wrecked. (The engine is still good, all it needs are body pieces and a radiator and fan.) That one clicked very quietly and turns out, a spark plug was very loose. (I don't know how but that's what we found and as soon as we tightened it, it quit. Doesn't make any sense to me.) I kinda think that what they have said is probably a closer to right but since I was told wristpins so long, maybe you might want to see if anyone knows anything about that being the problem. Just a suggestion (and I hope that's not the case!)
Connie (only Ford luvr in the family!)
'79 f100 "Silver Ghost" (my baby)
'83 f100 "The Ford" (my first)
'85 f150 "Old Blue" (my next project)
