4wd Shifter change
Old Oct 12, 2005 | 03:15 PM
95se5m's Avatar
95se5m
Question 4wd Shifter change
Did a search but didn't find anything helpful. I have a 95 f-150 XL winter daily driver and a 90 f-150 XLT Lariat yard truck. the 4x4 shifter on the 90 has kind of an offset pattern to it, strait back is 4 high, to the left and back is Neutral, and then back and to the right is 4 Low, can't be knocked out of 4 low, and can't be accidentally shifted from 4 high to 4 low.
My 95 however all the points are in a line, with somewhat crappy detents so if I want 4 high, I need to pull back, then push forward, then pull back all while trying to get it to sit between a set of detents.
Now my question. Can I take the shifter assembly from the 90 and place it in the 95, and put the 95 unit in the 90 (still need it for the yard, but stays in 4 low most of the time.)
Old Oct 13, 2005 | 02:32 PM
Mr Man's Avatar
Mr Man
You should be able to swap the shifters, as long as the shifter goes through the floor in the same location on each truck. Based on experience with my '87, my shifter from a C6 trans goes through the top of the transmission tunnel, and the shifter from a ZF 5-speed goes through the side of the tunnel.
If both trucks have the same transmission, you shouldn't have a problem.
Old Oct 14, 2005 | 12:31 PM
95se5m's Avatar
95se5m
They are both m5od transmissions with I6 engines, the shifter is in exactly the same place. I guess I know what I will be doing this weekend. :-)
Old Oct 14, 2005 | 04:22 PM
MustangGT221's Avatar
MustangGT221
You can't swap the shifters.
While they do bolt on, the 90's shifter handle is longer and hits the 95's dash.
You shouldn't have any problems with the 95 shifter...shifting from 2H to 4H is the same on both shifters...just pull back.
The 95's you pull back for 4H, the push down, pull back for neutral, and then drop back into 4L.
The 90s you pull back for 4H, left and back for N, then all the way back and to the right for 4L.
It should shift pretty smoothly, otherwise there could be a lubrication mishap going on...
stanz
39
Apr 11, 2011 03:25 PM
destruk
Feb 10, 2011 09:31 AM
Ztitan
16
Apr 14, 2009 07:54 AM
ivanribic
Offroad & 4x4
49
Feb 13, 2004 06:38 PM
laynrubber
May 30, 2003 04:20 PM
