95 F150 sloppy shifter- kit replacement- not in neutral - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Reload this Page >
Old 02-09-2011, 10:28 PM
destruk
destruk is offline
destruk is starting off with a positive reputation.
Hey guys,
I pulled my shifter out today, and discovered there indeed was a broken pin and worn out bushings that need replacing.
Only trouble is, it was not in neutral when i pulled the shifter from the top of the tranny... and when i put it all back together it was locked up.
Is there something I can do, like push some gears around in there before re-inserting the shifter?
Any help would be much appreciated!
Old 02-10-2011, 10:31 AM
SilverSport
SilverSport is offline
SilverSport is starting off with a positive reputation.
Replied in other thread ... but here is a copy of what I wrote.
I replaced the tranny in my 90 about a year ago. I did the same thing, well, the rebuilt was in a gear from the rebuilder .... Had reverse and one other gear. I really did not want to remove the tranny again and did not have to. Remove the shifter and get one of those big long flat blade screwdrivers and stick it in where the shifter goes, move it around like you are shifting and watch what is going on, you may need another lever or screwdriver to move everything into alignment and get it to neutral. After it is in neutral put it all back together and drive away!
oct7brian
1999 to 2016 Super Duty
19
01-13-2015 06:04 PM
tjc transport
52
12-23-2014 07:17 PM
broncoman1532
05-18-2013 09:12 PM
M998
10-21-2006 04:16 PM
jaydub318
11-20-2004 07:44 PM
Quick Reply: 95 F150 sloppy shifter- kit replacement- not in neutral
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
