Steering column question
Old Oct 12, 2005 | 02:19 PM
rmalottwtes30's Avatar
rmalottwtes30
Is there any differences in a steering column with shifter on the column out of a 1976 is any different than a column out of a 1978 without a shifter on column, anything with the turn signal switch, all I know is that the switch looks different , so is the wiring out of the turn signal switch different, if I were to put one out of a 1978 in my 1976 will it work correctly?
Old Oct 12, 2005 | 02:32 PM
Mil1ion's Avatar
Mil1ion
The difference is the hazard lights & Back-up switch
The 77/78/79 hazard switch is on the column.
The 78/79 doesn't have the BU switch on the column but it attaches to lever at the bottom of the column
On Earlier models Hazard light switch is on the dash .
The BU switch is also on the column.
You can interchange the newer column but have to change the wiring around.
Search "Column wiring" in this forum for more info.
Old Oct 12, 2005 | 05:48 PM
76supercab2's Avatar
76supercab2
Whoa there Million. If you're referring to the hazard switch you pull out to activate the lights, It is definitely located on the lower right side of the column on a 1976 truck. It's an integral part of the turn swithc assembly and I think that turn signal switch is good for 73 to 76
Old Oct 12, 2005 | 09:36 PM
Mil1ion's Avatar
Mil1ion
Hmmmm ?
I'll go look again.
Maybe I'm thinking 72 & earlier but I don't think so.
Old Oct 12, 2005 | 09:47 PM
hotroddually's Avatar
hotroddually
both my 74 and my 79 have the hazard switch on the column. my 74 is a 4x4 with a 4 speed,my 79 is an automatic with cruise and is 2 wheel drive. so i would have to agree with 76supercab2-billy
thunderbirdcakes
Sep 24, 2012 12:26 PM
healthful
Nov 4, 2011 02:15 PM
brseidel
Oct 15, 2010 06:13 PM
RCrawler
May 3, 2010 09:57 AM
69f100longbed
Feb 14, 2010 01:02 PM
