1978 - 1996 Big Bronco
5.0 /302 same thing?
Old Oct 12, 2005 | 01:47 PM
jgc2521's Avatar
jgc2521
title says it all j/w tryin to do the KBB on this thing
Old Oct 12, 2005 | 01:55 PM
andym's Avatar
andym
Same thing.
Old Oct 12, 2005 | 02:46 PM
skelator84's Avatar
skelator84
yes 5.0 reffers to 5 liters and the 302 is cubic inches. although it is not exactly 302, ford likes round numbers.
Old Oct 12, 2005 | 02:56 PM
jgc2521's Avatar
jgc2521
i was thinking that. just amking sure i wasnt halucinating or somethinf
Old Oct 12, 2005 | 03:02 PM
skelator84's Avatar
skelator84
Its a good question, took a while for it to sink in with me also. once you learn stats its easy to remember. 5.8liter is 351 cubic inches and so on.
Old Oct 12, 2005 | 09:00 PM
G Lube's Avatar
G Lube
Is there a formula to convert one to the other and vice versa?
Old Oct 12, 2005 | 09:19 PM
Streetgang's Avatar
Streetgang
Here you go........
5 liter = 305.1187192 cubic inch
1 liter = 61.0237438 cubic inch
1 cubic inch = 0.0163871 liter
302 cubic inch = 4.9488933 liter
You can click on this link for the conversion chart I used.
http://www.onlineconversion.com/volume.htm
Old Oct 12, 2005 | 10:03 PM
G Lube's Avatar
G Lube
What makes that interesting is if you were to round off both the exact "literage" for both the 300 and the 302 they should both be 4.9L engines. I guess ford should have thought a little better when they made these 2 engines so close in size.
Old Oct 13, 2005 | 02:10 PM
greystreak92's Avatar
greystreak92
Since the 302 is a derivative of the original 289 the CID numbers were upped to sound "bigger" when the shift to the 302 over the 289 was implemented.
I still miss my 7.7 litre Cadi once in a while.
Greywolf
19
Apr 28, 2012 04:50 PM
lakecityg
21
Sep 28, 2009 04:21 PM
mgazak
Jun 19, 2002 06:52 PM
