1978 - 1996 Big Bronco
My new bronco
Old Oct 12, 2005 | 08:27 AM
danny_g_76's Avatar
danny_g_76
My new bronco
I just got a 79 bronco with a v-8 i dont know if it is the 351 5.8L or the 400. is there some ways i can find this out.
dan
Old Oct 12, 2005 | 09:50 AM
satx77stepside's Avatar
satx77stepside
dan
Not really an easy way. I believe about 1/3 of the '79 broncos had the 400 and the other 2/3's had the 351M. The only way to tell the difference is by measuring the stroke. 351M = 3.5", 400=4.0". I'm not sure if there is an easy way to do this without removing the heads. Maybe you can pull a spark plug and measure from TDC to BDC? Can anyone else verify if this method would be accurate enough to work?
Old Oct 12, 2005 | 10:05 AM
plowpusher's Avatar
plowpusher
if it's oem motor look mat the door tag it'll tell you otherwise they are pretty much the same appearance wise
Old Oct 12, 2005 | 12:33 PM
77460f150's Avatar
77460f150
Try to decode your VIN # at this link http://www.medicine.wisc.edu/~mrm/bronco/ftvin.cgi, that will tell you what it had from the factory. (I'm assuming that its the original engine) I'm sure you have already looked but, I didn't se it mentioned in any of the reply's yet, If it has not been taken off or fell off there should be an engine spec. sticker on the left valve cover (driver's side) that will state the engine CID. Not real sure if it states exact CID or 351M/400M. -Ed
Old Oct 12, 2005 | 08:04 PM
MBBFord's Avatar
MBBFord
Check the valve covers or do the vin decoder thing, those would be the easyest ways.
Old Oct 13, 2005 | 09:37 PM
dixiebronco1986's Avatar
dixiebronco1986
lmc has a vin decoder too
