Glow plug broadcast message
Old Oct 11, 2005 | 12:56 PM
powerstroker04's Avatar
powerstroker04
I know some of the 6.0's have oil leaks coming from the glow plugs. I think it might be the o rings-not sure. Anybody know if there is a broadcast message out on this and what it says. Thanks, Mike
Old Oct 11, 2005 | 03:50 PM
laredo7mma's Avatar
laredo7mma
I am not sure of the broadcast message, but I had all 8 of my o-rings replaced a few weeks ago (along with the rms).
Old Oct 11, 2005 | 04:08 PM
powerstroker04
Mine are being done right now. I was kind of hoping that was the cause of the bell housing stain and not the rms
Old Oct 12, 2005 | 11:59 PM
n6nfg's Avatar
n6nfg
That was my problem also, thought it was RMS, but turned out to be the glow plug seals. Dealer put dye in the oil and confirmed this leak.
Old Oct 18, 2005 | 04:51 PM
jorzac's Avatar
jorzac
How evident is the glow plug leak? Is it easy to spot?
Old Oct 18, 2005 | 06:39 PM
powerstroker04
Just look through your wheel wells with a flashlight. If leaking, the glow plugs will have an oily residue all around them. Mine never leaked on the ground, but a dealer oil dye test confirmed oil was leaking from them. They changed the glow plug harness on both sides and after one week there are no leaks.
Old Oct 20, 2005 | 05:53 PM
iceman5's Avatar
iceman5
I just had the RMS replaced and the dealer replaced #8 glow plug o-ring. 25K miles.
