94 Explorer Transmission flush
Old Oct 11, 2005 | 10:53 AM
poknox's Avatar
poknox
Does anyone know how to flush the transmission on the A4LD transmission with out taking it to a tranmission shop. I would like to be able to do this myself. Any help is appreciated.
Old Oct 12, 2005 | 11:49 AM
jwh's Avatar
jwh
Check out this site:
http://draco.acs.uci.edu/explorer.
It has how to do this, plus a wealth of other handy info.
John in Rochester NY.
Old Oct 13, 2005 | 06:54 AM
ukexplorer's Avatar
ukexplorer
Also try this Amsoil site, it's good. Pity I can't buy these products on the UK!
http://www.amsoil.com/faqs/faq8.aspx
Old Oct 14, 2005 | 07:30 AM
Bob Ayers's Avatar
Bob Ayers
I flushed my Ranger myself, by:
1) Mark a bucket at the 1 gallon level
2) Disconnect the tranny cooling lines at the radiator
3) Start the motor and run till 1 gallon is pumped out
4) Add 1 gallon of new ATF (ONLY Mercon V if that's what is called for)
5) Repeat steps #3, and #4, stopping after the 3rd gallon is pumped out
6) Drop tranny pan, replace filter. Be very careful to clean everything well, and only use "lint free" cleaning cloths!!
7) Install tranny pan, and cooling lines
8) Add 1 gallon, plus any more required to bring the tranny level up to the proper level. Make sure you check the level hot, DO NOT overfill.
DO NOT use any multi-purpose synthetic ATF, like Amsoil!!!!!!!
Old Oct 14, 2005 | 07:34 AM
Bob Ayers's Avatar
Bob Ayers
I would consider it a blessing that you can't get Amsoil products in the UK!!
Watchout for the deceit, and lies on the Amsoil website! They try and make you think that all their motor oil products are API certified, in reality only a few are API certified.
http://eolcs.api.org/DisplayLicenseI...LicenseNo=0995
Old Oct 17, 2005 | 08:48 AM
ukexplorer's Avatar
ukexplorer
98 Explorer ATF
I know this is an old discussion but the reply from Bob Ayres has made me think. Ford has told us to use nothing but Mercon V in transmissions newer than '96. But this is not available in the UK even from Ford! Last year I flushed and filled my 5R55E with 76 Mercon V, which is all I can get in the UK.
First question, is this OK?
Second, can anyone suggest anything else?
Great site!
ukeplorer
Old Oct 17, 2005 | 10:06 AM
srercrcr's Avatar
srercrcr
Mercon V is a semi-synthetic, so if you ask me, a full synthetic would be acceptable...even preferable. Amsoil sells such an animal.
Old Oct 17, 2005 | 10:11 AM
Bob Ayers's Avatar
Bob Ayers
No, Ford came out with a TSB to ONLY use Mercon V in Mercon V applications. The friction modifiers are wrong in anything else!!
Old Oct 17, 2005 | 02:39 PM
srercrcr's Avatar
srercrcr
I hear that!
Old Oct 19, 2005 | 10:54 AM
ukexplorer's Avatar
ukexplorer
So where do I get Mercon V in England?
Old Oct 20, 2005 | 09:40 PM
98xlt's Avatar
98xlt
Don't the ford dealers in the UK sell parts and lubrication fluids?
Old Oct 22, 2005 | 03:28 AM
ukexplorer's Avatar
ukexplorer
Thanks 98XLT. No they don't sell Mercon V. I can get 76 Mercon V from some one who import it in large quantities and that's what I use. Is 76 Mercon V any good?
Old Oct 22, 2005 | 03:33 AM
ford390gashog's Avatar
ford390gashog
76 Mercon V is fine it is made by 76 lubricants it meets the specs for mercon v it is a semi synthetic fluid . it will work fine in your application and any other that requires mercon v.
Old Oct 22, 2005 | 10:01 AM
ukexplorer's Avatar
ukexplorer
Thanks ford390gashog
jawdoc
Dec 5, 2013 05:15 PM
emd160
6.7L Power Stroke Diesel
Jun 14, 2013 08:58 AM
jayhawk714
Oct 27, 2011 05:56 PM
JimBrazil
Nov 14, 2009 06:42 AM
ptt
Nov 28, 2006 09:00 PM
