Dp V-clamp
Old Oct 11, 2005 | 09:55 AM
marvinlong's Avatar
marvinlong
Dp V-clamp
before changing out my DP to 4in. is it advisable to put on a new v-clamp? reason i ask it is a far cry from hear to get one. are there any tell tale signs or past experiences with this sort of thing before i get started? hate to start something i cant finish. oh,what would i use for a butt joint besides welding? am going from 4in.with welded on 3.5 reducer. 3.5 to 3.5 butt joint. bandclamp?
Old Oct 11, 2005 | 10:08 AM
Kwikkordead's Avatar
Kwikkordead
Depends on the condition of the existing clamp. I reused mine, it was in perfect condition. They are just stubborn to remove, they can get themselves seated down real tight. The way that I dislodged mine was to apply Free all and then some gentle persuation with a drift punch on the side of the clamp in the direction of removal. It popped right off.
Old Oct 11, 2005 | 10:31 AM
Fordafied's Avatar
Fordafied
I re-used mine also. Just be careful getting it off. I used several small screwdrivers. It does take a little persuasion.
Old Oct 11, 2005 | 12:55 PM
marvinlong's Avatar
marvinlong
thanks guys,i shall proceed
Old Oct 11, 2005 | 07:42 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The only time that clamp would need replacing, other than you twisted it all up, would be if it tightened up so far that the ends pull together. At that point the clamp has stretched beyond it's usable means, but normally it would have to be torqued many times before reaching that point.
Old Oct 11, 2005 | 08:31 PM
johnny8's Avatar
johnny8
i put a crowbar on mine and LIGHTLY tapped on that with a hammer... it came off easily.. and i have almost 96k on my mule.. so that clamp had been on there awhile...
superv10
May 10, 2012 11:18 PM
High Binder
Oct 13, 2010 09:00 PM
s2gots
Oct 15, 2007 07:07 PM
marvinlong
Mar 28, 2006 11:06 PM
marvinlong
Nov 13, 2005 07:29 PM
