major light problem
Old Jun 2, 2002 | 10:41 PM
mtford1's Avatar
mtford1
major light problem
[updated:LAST EDITED ON 02-Jun-02 AT 11:45 PM (EST)]I have a major light problem on my 77 f250 4x4. When i push on the brakes my parking lights come on. When the drivers side turn signal is on all my lights except the headlights and reverse lights flash. When my headlights are on, the driver side turn signal is on steady. Also when my lights are on the drivers side turn signal wont work. Its driving me nuts!! I've cleaned and or changed all the grounds on the chassis and the lights themselves. Its ticking me off. Is it a relay or something under the dash or something. Any suggestions to this problem?
mike
Old Jun 2, 2002 | 11:28 PM
tellico racing's Avatar
tellico racing
major light problem
ive had wierd stuff like this happen to me and it turned out to be the light sockets. changed them and the problem went away. I dont know if this will work for you but they are all probably still original. also check for trailer wiring in the back corroded and messed up
Old Jun 2, 2002 | 11:48 PM
sparky's Avatar
sparky
major light problem
Kind of sounds like a couple of problems It sure acts like a ground problem also a messed up turn signal switch.
Sparky
Old Jun 3, 2002 | 01:58 PM
Jermafenser's Avatar
Jermafenser
major light problem
I think you may need to call a preist!
Old Jun 3, 2002 | 10:30 PM
trinogt's Avatar
trinogt
major light problem
Once you've made sure all the bulbs are good, have a look at the passenger side signal bulb and socket. Use a tester if you have one.
If that doesn't cure the problem, go to the wreckers and find a signal switch. You will have to pull the steering wheel for this. I have seen two types of switch in the 73-79 range, so find the right one. Just unplug your switch (under the dash) and plug the 'new' one in without trying to mount it. Remember, this is just for testing. If it works, there's your problem. Signals and brake lights (hazards) run through this switch, and many strange things can happen when they go; trust me!
Mark
Ford started it; Ford will finish it!
Old Jun 3, 2002 | 11:20 PM
Vampiro's Avatar
Vampiro
major light problem
check your bulbs, swithces and the ground wires
Old Jun 4, 2002 | 07:40 AM
fatdaddy's Avatar
fatdaddy
major light problem
If you have bad ground(s) the lights wouldn't work at all since the circuit wouldn't be completed---some idiot has tied the 12vdc output from the brake light switch into the clearance\parking light circuit------the lights don't care where the voltage comes from----the same idiot has cross-wired several different circuits under your dash----I think you will need to pull the instrument cluster so you can see the wiring behind the dash-------More than likely this idiot probably used those little splicer crimps and you will beable to trace the circuits based upon color codes of the individual wires---maybe it won't be too bad once you can see how everything is hooked up behind the dash!!!!!!!fd :-X11
Old Jun 4, 2002 | 12:05 PM
russellkr's Avatar
russellkr
major light problem
I had a similar problem in my 76 F250, turned out the sockets needed a good cleaning and some of the bulbs needed replaced, also I cleaned the connector under the rear bumber where the forward harness attaches to the rear.
Now good as gold
Old Jun 4, 2002 | 01:08 PM
Franklin2's Avatar
Franklin2
major light problem
fatdaddy, the front turn signal lamps and the rear brake/marker lamps use a dual filament bulb. Both filaments have separate wiring leading to them, but are tied together in the bulb for the return path to ground. If you have a bad ground in the light socket, the electrical current running through one of the filaments, can actually run backwards up through the other filament, and find a ground through the other circuit in the truck, causing strange things to happen.
Old Jun 4, 2002 | 04:59 PM
fatdaddy's Avatar
fatdaddy
major light problem
Hells-bells as grandma use to say--sounds like a transvestite\engineer\chebby person designed the circuits for these damned ole' fords after he was fired by GM---!!!!!!What's the world commin'too???fd :-X11
Old Jun 4, 2002 | 06:52 PM
Torque1st's Avatar
Torque1st
Posting Legend
major light problem
Actually the lights and electrical systems in those old Fords are absolutely rock simple, check out a wiring diagram. Mil1ion probably has one! All I have is some for an 85 E150. All of those old 70-80 fords are very similar. The problem with bad grounds and stray currents are universal. If anything I have found that the materials and workmanship are better in Fords than GM.
Electrical systems and failure symptoms can be very confusing to anyone without a knowledge of elctricity and basic Ohms Law and how to apply it. Enough to make one believe in gremlins, demons, ghosts, and evil spirits.
Old Jun 5, 2002 | 10:17 PM
mtford1's Avatar
mtford1
major light problem
Thanks for all your input so far. I've double checked all the bulbs and various grounds and they are all good. When i have a chance on the weekend i will check the sockets and then if i have to under the dash and so on.
mike
Old Jun 6, 2002 | 01:55 PM
BEAVER's Avatar
BEAVER
major light problem
Mike,
If you haven't already check the condition of the wiring harness from the front of the truck all the way to the back. I had the same exact problem with my '77 F-250 a few months ago. I tried changing all the sockets, bulbs, etc., but nothing seemed to fix it. When I checked the wire harness, I found where it had been chewed bad. Probably from a mouse when it had been sitting. The bare wires were rubbing against the frame and causing everything to short. I cut out about 18" an spliced new ones in. That solved my problem. Good luck.
Brendan
1977 Ford F-250 4X4
351M / 4-Speed
33" BFG Tires
www.angelfire.com/ma4/1977fordf350
Old Jun 6, 2002 | 05:44 PM
gray79f250's Avatar
gray79f250
major light problem
