HEI for 68' 289
Old Oct 10, 2005 | 02:52 PM
mt54's Avatar
mt54
HEI for 68' 289
Anyone have any thoughts on a good doner engine and year that I could get a HEI for my 289 build.
Thanks
Mike
Old Oct 10, 2005 | 06:50 PM
Franklin2's Avatar
Franklin2
I assume you are looking for a Ford Duraspark II ignition? Any 302 about mid 70's up should have what you need, car or truck, Ford, Lincoln, or Mercury. Look for the aluminum box on the fender that has a blue plastic piece where the wires go in. Some others have different color plastic pieces and are not the best to get.
Old Oct 10, 2005 | 10:33 PM
imlowr2's Avatar
imlowr2
Why would you want a HEI unit? Go with the Pertonix ignition. It's simplier and works great. You can still use your original distributor and rotor/ cap. I use em in all my vehicles.
Old Oct 11, 2005 | 06:52 AM
mt54's Avatar
mt54
What I really was looking for is a dist. that I can put in that is self contained, coil and all,with no other control boxes or such. I guess I'm not really sure that such even exist.
I'll take any and all ideas to update my ign. system.
thanks
Mike
Old Oct 11, 2005 | 08:31 AM
TigerDan's Avatar
TigerDan
What you want is the Davis Unified Ignition. It's basically a GM HEI unit grafted onto a Ford distributor body:
http://www.performancedistributors.com/forddui.htm
Comes in several different flavors. If you can stomach the thought of a Chevy ignition on your Ford, they're supposed to be pretty good. I've never used one myself.
Its size can be an issue in some cases.
Old Oct 11, 2005 | 10:40 PM
captainkirk's Avatar
captainkirk
I had trouble with the duraspark ignition on my truck since I got it. The DUI ignition was a bit pricey, about $385, but thats really not so bad considering that it includes the coil, it is machined out of billet aluminum, and you can use your stock wires if you need to. I pulled the stock ignition, dropped in the dui unit, hooked up the 12V source, (that's all you need to run it!) The engine started easier, runs smoother and makes more power. I have had not had trouble with it since. This is the only way to go.
Old Oct 12, 2005 | 08:18 AM
mt54's Avatar
mt54
Thanks for the advise guys
Mike
Old Oct 13, 2005 | 09:26 PM
99FordGuy's Avatar
99FordGuy
I just got one of the GM type HEI distributors for a 351w I'm building. It is a one wire unit so it's easy to hook up. I got it on ebay new for $120 bucks. I'll let you know how it works when I get the motor finished.
Old Oct 14, 2005 | 11:27 AM
mt54's Avatar
mt54
Sounds good, I was looking at them on ebay also.I'll be looking forward to hearing.
Mike
Old Oct 14, 2005 | 09:40 PM
70blue's Avatar
70blue
If you must go HEI this one will be alot less expensive than a DUI ignition. http://fastengineparts.com/products_view.php?id=1650
