Sponsored by: Real Truck
Snomobile on tailgate?
Old Oct 9, 2005 | 09:36 PM
Gray Wolf's Avatar
Gray Wolf
I have a 680 pound touring snomobile and would like to load it in the back of my 2005 F350 using the ramps I already have for my flatbed truck. I weigh around 225 on a good day. Total riding up the ramps is therefore around 900 pounds. At one point in the drive up to the bed the tailgate would have to support pretty much the entire load. Can those cables and the tailgate handle that much weight?
Old Oct 9, 2005 | 10:25 PM
BareBones's Avatar
BareBones
Don't confuse my response with that of someone who actually knows, but it seems to me that half of the load on the tailgate would be on the hinges, and half on the cables - at least if the load were in the center of the tailgate. In that case there would only be 225 pounds on each cable, which I wouldn't expect to be a problem.
The problem would be if/when all of the weight is on the aftmost lip of the tailgate.
On the other hand, the ramps also redirect some of the load to the ground. In fact, you could cut a couple of 2x4's and wedge them under the ramps up by the gate to ground to take a lot of the load off the tailgate.
Also, at any one time only some of the weight would be on the skiis, and some spread out on the belt, not all in one pinpoint location.
You're right though, best bet is to hear from someone who has tried it...
Old Oct 9, 2005 | 11:08 PM
EnviroCon's Avatar
EnviroCon
Why not just remove the tailgate?
Old Oct 9, 2005 | 11:20 PM
jake00's Avatar
jake00
i've loaded many sleds into my truck with no probs. what kinda sled ya got that weighs 680 lbs?
Old Oct 10, 2005 | 04:43 AM
rollnthunder_76's Avatar
rollnthunder_76
loaded a big kawasaki mule in the back of my buddies all the time and thats one heavy beast.
Old Oct 10, 2005 | 05:10 AM
Jerrybo66's Avatar
Jerrybo66
My Arctic Cat ATV weighs over 600# and because I have bars rather than cables I'm more conserned about bowing the tailgate. As easy as it is to take off I remove it and put a 4x4 on the bumper and the ramps on that. If a cable would come apart it would sure bend up the gate...
Old Oct 10, 2005 | 06:26 AM
mountaincat900's Avatar
mountaincat900
Loaded a 500 lb Snowmobile, and a 600 lb 4 wheeler, I weigh 220 . I have never had a problems with the tailgate being down! I guess I should say both weren't loaded at the same time!
Old Oct 10, 2005 | 06:54 AM
350z's Avatar
350z
Ive loaded my sleds that way many times , never had a problem, Craig.
Old Oct 10, 2005 | 11:20 AM
Gray Wolf's Avatar
Gray Wolf
I could remove the tailgate but the snomobile is longer than 8' and I would have a problem getting the machine lifted up enough to slide the ramp under the track at the same time. My flatbed pickkup was long enough so this didn't matter till now.
Old Oct 10, 2005 | 11:28 AM
Gray Wolf's Avatar
Gray Wolf
I'm guessing on the weight a bit but the dry weight is around 600 pounds and with full gas and oil and stuff in the trunk I think I'm close.
All weight will be on the back lip of the tailgate until the tracks flop down on the bed, then the tracks and I will be pushing down on the middle of the tailgate.
I've done this before but not with a BRAND NEW pickup.
Old Oct 10, 2005 | 01:04 PM
EnviroCon's Avatar
EnviroCon
Wow, longer than 8ft, now that's a snowmobile. My guess is that if the strength of the tailgates has not changed between '04 and '05, then it will hold-up. I had a forklift operator accidentaly lower a pallet with around 1200# of lead bars on my tailgate. No damage to the tailgate, but my nerves will never be the same.
Old Oct 10, 2005 | 01:16 PM
Gray Wolf's Avatar
Gray Wolf
Two person - long track snomobiles are all about 10' long overall. Maybe a bit more depnding on model etc. Both of mine are about 8'-6" from the nose against the back of the pickup box to the back end of where the track sits on the bed and about 10'-6" overall.
Unless somebody knows the specs on those cables and the tailgate itself, I'm leaning towards taking off the tailgate and welding up some sort of slide in frame that will extend past the end of the box for me to sit the ramp on.
Old Oct 10, 2005 | 02:58 PM
EnviroCon's Avatar
EnviroCon
Last time I was down in Mexico I saw a guy that had a "ramp holder" built out of square tubing that fit into his trailer hitch. I don't know if it was home made or bought, but it seemed like a good idea. It looked as easy to put in and take out as one of those trailer hitch bike carriers. Once he was done loading the quads he took the ramps off of it, threw the ramps in the bed, and he was off with the ramp hitch still in place. Just a thought.
Old Oct 10, 2005 | 03:20 PM
bigford8486's Avatar
bigford8486
i always load my polaris xc 700 hp in the bed of my truck and there is no probs what so ever and im a heavy guy.
Old Oct 10, 2005 | 07:38 PM
jcullom's Avatar
jcullom
Any chance you could make a drawing of it? I'd like to see how it worked.
