Pulling power
Old Oct 9, 2005 | 05:36 PM
limakid's Avatar
limakid
Pulling power
I have a f600 with a 370 2v enigine in it with the standard 4 spd. What is the max i can pull with this truck..i''ve pulled a 20 000 pound trailer with the flatbed loaded to the max b4 but the was a little iffy and prob wont do that again...was wondering if i just pulled the 20 000 pound trailer i would be good. The truck is an 86 but only has 26000 miles on it an i am the original owner...well my father is
Old Oct 10, 2005 | 07:07 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 10, 2005 | 11:12 AM
Brad Johnson's Avatar
Brad Johnson
You can pull a whole lot more than you can get safely stopped, or that the trailer axles can handle without being mashed into oblivion.
Brad
Old Oct 10, 2005 | 11:17 AM
limakid's Avatar
limakid
Well the entire brake system was just replaced and updated all around and new master and what not....our old trailer was stolen and i'm looking to buy a new trailer with a 21000 gtwr which is perfect for my needs all together i think the max load on the trailer including its weight will be around 18 000 pounds or so. I'm not to worried about the braking system...i'm very happy with its performance and i'm having all 3 axles on the trailer with brakes. THe only problem with pulling this much weight is making it up hills....i can move 10 000 pounds on the flatbed and get started no problem...it has gobs of pulling power in the low end but when wanting to make it up inclines it runs out of steam....i dont have the optional 2 spd rear and was looking at maybe swapping one in but i think in 2 or so years i'm upgrade my truck to a new f750...they are some nice units and of course diesel power . Anyways thanks for the reply if any one has any more suggestions aside from telling me this engine is useless...because its really not...it is a beast of an engine if you know how to use the transmission to your advantage
Old Oct 10, 2005 | 01:49 PM
turbo2256's Avatar
turbo2256
Has that got the dual inlet 2 1/2 to 3" out exhaust in it? Does it run out of steam a bit over 3200?
Old Dec 25, 2005 | 06:57 PM
ron_29_1973's Avatar
ron_29_1973
another thing you could do is find a 4barl intake and carb that would give it more power. the 370 came both way's 2barl and 4barl i know where a 4v intake is if your interested let me know.
grpark20
All Things Towing
39
Jul 6, 2017 10:19 PM
06pghescape
All Things Towing
Feb 23, 2017 03:04 PM
43tutor2
All Things Towing
Jul 7, 2016 07:47 PM
lasitter
Dec 19, 2009 11:16 AM
SDTruckMan
2004 - 2008 F150
19
Mar 22, 2007 03:07 PM
