Sponsored by: Real Truck
2005 full exterior conversion??
Old Nov 8, 2005 | 08:56 PM
crosscity's Avatar
crosscity
does anybody know if a excursion grille will fit in a 04 f 250
Old Nov 8, 2005 | 09:17 PM
RACERX7775's Avatar
RACERX7775
If You Want To Install An Old Style Grill. Just To Let You Know, The 04 And Older Will Be An Exact Fit. For Aftermarket Grills, The Main Grill Is The Same As A Super Duty, But, Its Hard To Tell, But The Side Vents Are A Little Different... If You Want To Install A Factory 04 And Older Excursion Grill In Your Duper Duty, It Will Be An Exact Fit. Simply Remove The 4 Screws At The Top Of The Shell And Release The 4 Spring Clips At The Bottom Of The Shell And Remove The Assembly. Its About A 2 Minute Job, Total..
Old Nov 8, 2005 | 10:39 PM
crosscity's Avatar
crosscity
thanks racerx7775 just thuoght about doing somthing a little differant
