2002 ABS controller (module) where is it?
Old Oct 9, 2005 | 01:06 PM
SBChero's Avatar
SBChero
i have the truspeed calibrator but i dont know where the abs controller is. the instructions say that it is either under the battery box or on the drivers side fender well.
i see all the plugs on the fender well but i dont know which one is the abs controller.
anyone got a pic of what it looks like? or describe it?
thanks.
Old Oct 9, 2005 | 02:20 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Do the instructions identify the wire color you are looking for? The ABS controller is under the battery box, and is a PITA to reach.
If you know the wire color needed you might be able to find it inside the cab.
Old Oct 9, 2005 | 03:01 PM
SBChero's Avatar
SBChero
found it.
ya its a gry/blk wire.
but i found it.
it is just infront of the battery box and lower than it. i moved the wheel liner and got to the wires. and found the one i was looking for.
thanks though.
Old Oct 9, 2005 | 03:28 PM
cookie88's Avatar
cookie88
FTE Emeritus
Cool. The gry/blk wire also runs to the instrument cluster....so it is in the cab too if you needed it.
Old Oct 10, 2005 | 07:22 PM
SBChero's Avatar
SBChero
that would have been easier but i spliced into it by the abs module. it works great. i now have an accurate speedo.
Old Oct 10, 2005 | 08:25 PM
cookie88's Avatar
cookie88
FTE Emeritus
Awesome. How hard is it to dial in the truspeed to get the accurate measurement?
Old Jul 15, 2006 | 05:42 PM
SBChero's Avatar
SBChero
talk about bringing one up from the dead.
i didnt see that last post.
i have a gps reciever and used that to get it spot on. the method that they tell you gets you close. (they have you calc a % difference and then adjust the calibrator according to that).
w/ a gps it took me about 3 different adjustments and it was perfect.
