batty 302
Old Oct 8, 2005 | 08:22 PM
quisp-n-quake's Avatar
quisp-n-quake
batty 302
I picked up an '88 F150 back in june, and have been monitoring the motor since, its noisy on start-up, and quiets down after it reaches operating temp
but i got noise coming from the timing gear area, thought at first it could be the water pump, but i'm starting to drift away from that thought now.
I got a 2 inch folder full of work receipts done to the truck since 1988, and found a work order for timing gear and chain replacement back in '01,
question #1: could the timing gears go after only 4 years?
Its got the duraspark 3 dist in it as well, which seems to control the spark advance by computer on acceleration/decellerating,
question #2: could the mechanism in the distributor/computer lose its acuracy after time and leave the distributor sloppy and slightly out of time? I know it doesnt have the internals of earlier distributors.
question #3: could the drive gears, or shaft of the oil pump make noise come from the front of the block?
I just tryin to prevent denting in the hood of the truck from me bangin my head against it tryin to figger this out....
Old Oct 9, 2005 | 06:44 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
