Offroad & 4x4
cutting tires
Old Oct 10, 2005 | 10:31 PM
  #31
RubberDuck's Avatar
RubberDuck
In my opinion the beat all kill all paddle tire. They are basicly a slick with kevlar scoops adheared to them. Except the scoops don't run all the way across the tire. The are staggered. Do a search on the web. But if you can't get traction with those in the mud you might as well pick a different hobby. Anyway, just a sick *** paddle tire.
RubberDuck
Old Oct 10, 2005 | 10:47 PM
  #32
mustange70's Avatar
mustange70
damn straight rubber , wish i had the power to turn a set of them tires (i watched a rail with 2500hp run a set of those front and back, i think he touched the mud 3 times then launched about 25ft out the other end of the pit).
Old Oct 10, 2005 | 10:52 PM
  #33
RubberDuck's Avatar
RubberDuck
You said rubber Huh, Huh
RubberDuck
Old Oct 11, 2005 | 08:52 AM
  #34
RawPower's Avatar
RawPower
oh cool, so you kinda set up our own tread pattern right?
Never heard of them before...thats pretty nifty
Old Oct 11, 2005 | 03:26 PM
  #35
mustange70's Avatar
mustange70
Yep i said it .
Old Oct 11, 2005 | 06:34 PM
  #36
BroncoRoadKill's Avatar
BroncoRoadKill
Hey rob were do get a cutter like that, wouldnt a regular sawzall work just as well?
Old Oct 11, 2005 | 08:42 PM
  #37
fishmanndotcom's Avatar
fishmanndotcom
Originally Posted by monsterbaby
I am doing the same thing using a modified sawzall blade then using a heated tire groover to finish them and after that I will use a special grinding wheel for use on tires to get the final shape.
http://www.google.com/search?q=tire+...en-US:official
-cutts-
Old Oct 12, 2005 | 12:38 AM
  #38
monsterbaby's Avatar
monsterbaby
not sure what you mean, I have a regular sawzall. I just modify the blades for cutting if you mean a regular blade no if you leave the teeth on the blade it would be faster to naw the lugs off with your teeth.
And if your talking about the tire groover I used for shaping, and finishing work then fishy gave a good link there, you can also find them on evilbay, or anyplace that sells to the stockcar or sprint car guys a lot.
Old Oct 12, 2005 | 08:47 PM
  #39
BroncoRoadKill
Oh yea, sorry bout misunderstanding, the tire groover is what I was refering to.
I thought it was just a nicer griped sawzall.
question anwered anyway rob,thanks, and thanks for the link fishy.
Old Oct 12, 2005 | 10:13 PM
  #40
fishmanndotcom
its all gravy!
-cutts-
Old Oct 15, 2005 | 07:04 PM
  #41
monsterbaby
Well I got the tires done as much as I am gonna this year. Got the new gears in, and put the tires on tonight, even after I chopped a full coil out of my rear springs this sucker still sits high in the rear kinda wondering if I shouldn't jake it back up, and take another coil out but I don't want to drop it so far I run out of shock travel under compression, and don't hve time to rebuild the shock mounts even if I was so inclined since those shocks are going away over the winter. So guess I will just leave it there, and see how level it sits when I drop the air preasure down at the track.
Old Oct 15, 2005 | 10:13 PM
  #42
bremen242's Avatar
bremen242
just a dumb 9" question for you (since I think you run a rear 9 ), do you preload the bearings by measuring the bearing cap stretch, or by torquing the adjusters with a torque wrench?
Old Oct 15, 2005 | 10:17 PM
  #43
monsterbaby
dial indicator on the backside of the ring gear.
Old Oct 16, 2005 | 09:56 AM
  #44
monsterbaby
Well getting ready to load this thing up this morning heading for the track but figured I would take a pic with the new tires on it while it was still clean so for your viewing pleasure here ya go.
Old Oct 16, 2005 | 11:28 AM
  #45
fishmanndotcom
GET HER DUN!
we better get some video if your gonna tease us like that
-cutts-
