turn signal canceling switch
Old Oct 8, 2005 | 03:46 PM
Wheelin4fun's Avatar
Wheelin4fun
Smile turn signal canceling switch
if you have a 78-79 f series you will have a hard time finding a new switch. Ford dealers only go back to 1980. Napa computer spits out the wrong switch that looks completely diffrent. the good news is that a 1980 without tilt steering is almost the same. it has an extra wire for cruise controll that will have to removed and the steering column has to be modified because the 78-79 turn signal arm sets just a little higher.
Old Oct 8, 2005 | 11:42 PM
Shane269's Avatar
Shane269
Do you have picture of the modofications that needed to be made? Would this also work in a 1977? How about a part# for what you got?
Old Oct 9, 2005 | 12:22 AM
66f14evr's Avatar
66f14evr
if all you need is the plastic cam for a 78-79 you can get one from LMC for $14.95 #45-0732
Old Oct 9, 2005 | 12:23 AM
Mil1ion's Avatar
Mil1ion
The turn signal cancelling cam part is available for $7.00 at part stores that have a H.E.L.P section.
Old Oct 9, 2005 | 12:35 AM
66f14evr's Avatar
66f14evr
Are they available for 73-79 That would be nice
Old Oct 9, 2005 | 02:21 AM
Polkat's Avatar
Polkat
HELP has it. There are four heavy wire contacts on it, if it's the one I'm thinking of. They don't always align right and may have to be bent.
Old Oct 17, 2005 | 12:07 PM
katman469's Avatar
katman469
I bought one of those canceling cams from NAPA for my '78 with cruise and tilt, but the plastic was too soft-wouldn't work at all. A new switch from Auto Zone was $100.00! I ended up getting a switch from the junk yard, not sure what year, and had to modify it by cuttig the plastic some to fit my column. there was a small alignment pin on the bottom of my column that had to be cut off-kept shorting out. Two months now-no probs.
Old Oct 19, 2005 | 07:30 PM
Wheelin4fun
Smile
i do not have a picture do to the fact that my digital camera fell into a mud hole about a month a go. but the modification is simple all you have to do is take a die grinder bit about the size of your turn signal arm and grind a arc right below the arm about a 1/4 of inch. sorry about no part # i threw the box away already.
Old Oct 20, 2005 | 11:42 AM
77bigblock's Avatar
77bigblock
i bought one from NAPA for my 77. It was about $12. No cutting needed. They're out there. A lot of times at NAPA, they just need to look it up on the paper catalogs to get it right. I belive they changed them from 1977-1978 model years.
