460 engine mounts/perches
Old Jun 10, 2002 | 02:03 PM
Rocking M's Avatar
Rocking M
I've got a 460 at the machine shop. The 460 will be going in my 1976 F100. The truck has a six in it now, so I know I'll need new mounts. The question is are the mounts and perches the same thing. I found mounts in the LMC catalog, but they don't look like anything I have seen at the junk yard.
Also can anyone help me with an oil pan. The 460 came off of a 79 Lincoln so the oil pan won't work. Where can I find one that in compatible with my truck and my engine?
Thanks fellas
Old Jun 10, 2002 | 03:09 PM
tellico racing's Avatar
tellico racing
The engine mount is the rubber/steel part that bolts to the engine.The perch is the steel bracket bolted to the frame.
Old Jun 10, 2002 | 04:54 PM
KJKozak2's Avatar
KJKozak2
I have a 460 in a 78 F150 4x4. They did not come from the factory that way (only the 2wd came with a 460). I don't know where the perches came from but the mounts were home made. You can get conversion mounts (for a 78 anyways) from L&L.
As for the oil pan, several people say that a front sump 460 pan will not fit on a 4x4. Mine is a front sump and it's from a Lincoln and it works fine. I do have a 3" lift on top of the 3" factory lift so that may account for it fitting. I also recently took it off-roading and did some seriously rough trails and never hit the pan with the axle.
If you don't have a lift, get a rear sump oil pan. You'll also need to get the extended pickup tube since the pump is in the front. I don't know which vehicles have a rear sump, but when I called the bone yards around here, they just asked if I wanted front or rear sump.
Hope this helps.
Kevin K.
Old Jun 10, 2002 | 05:48 PM
Mil1ion's Avatar
Mil1ion
You will find a rear sump pan on a 460 Van.
If you don't,all you have to do it braze weld in a drain plug in an open area of the pan so the oil doesn't drain on to the crossmember.
[font color=red]Dennis
Calgary,Alberta,Canada[/font]
[link:www.ford-trucks.com/guidelines.html|FTEModerator]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
http://www.clubfte.com/users/mil1ion/Mil1ion.html
[font color=red]
Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
[/font]
Old Jun 10, 2002 | 07:23 PM
kenmt's Avatar
kenmt
If you can't find a rear sump 460 pan at the boneyards,you can buy a new pan,dipstick and tube,and the oil pump pickup tube from Ford for about $170,Just tell'em you want it for a 80's on up 4wd pickup.You will also need to replace one of your main cap bolts with a stud that supports the pickup tube-this is also available at Ford.
Old Jun 10, 2002 | 08:52 PM
Mil1ion's Avatar
Mil1ion
Here are the factory mounts.
http://www.clubfte.com/users/mil1ion/429460truckmotormounts.JPG
[font color=red]
[/font]
Old Jun 11, 2002 | 02:21 AM
jsworkman's Avatar
jsworkman
>yard.
>Thanks fellas
I just went through this swap with my 76 F250 this is the info I can pass on motor mounts I use the L&L mounts & towers for about $300. I used them beacuse the other kits I had found were for 2wd not 4wd you could use the Autofab kit http://www.autofab.com/2wd460.htm this is the web page address for Autofab http://landlproducts.com/enginekits.htm and this is the web page for L&L
Good Luck if you have any questions you can email me direct at jsworkman@mybluelight.com
John Workman
76 F250 Crew Cab Short bed 4x4
Old Jun 11, 2002 | 10:20 AM
laptopgeek's Avatar
laptopgeek
Rocking M --- you might want to do some browsing through my web site (under construction - www.beedzncomputers.com ); there you'll find the same setup using the L&L accessories. A little on the expensive side, but the parts should last through World War 3....
I'm using their headers and mounts and towers and alt brackets. The engine WAS a 6..the 460 came from an 87 E-3 van with a rear sump. You'll have to have the drive shaft shortened for use with a C-6, though...
Old Jun 11, 2002 | 06:13 PM
Rocking M's Avatar
Rocking M
laptopgeek,
What is L&L? Do you have a website for them? Thanks for the info and I found your website extremely helpful. I don't know if you have visited my website, but we seem to be working on very similar topics. My website doesn't have a lot of info yet, but it does have a picture of my truck.
I couldn't access any photos of your perches? Thanks
Old Jun 11, 2002 | 06:58 PM
GORSTEP's Avatar
GORSTEP
[updated:LAST EDITED ON 11-Jun-02 AT 08:02 PM (EST)] Wow is this convenient. I was just about to enquire about the same thing :-staun
Some one told me once that the mounts/perches etc from a 460 van could be used to put a 460 in a 1\2 ton 4X4. Anyone have any experience with this. I'm pretty cheap and can't see putting out $300 for perches.
I should know this but would like to be sure. Will the bell housing from a 351M bolt up to a 460? I know I need the flywheel and clutch assy from the 460 but what else?
Old Jun 12, 2002 | 08:08 AM
laptopgeek's Avatar
laptopgeek
Rocking M & Gorstep - here is the link to L&L products : http://www.landlproducts.com/fordbronco429-4606cyl.htm
No pictures of or "strictly" perches...right now...just some cute engine pix I thought you might like...more to come later (and SOON..)
Old Jun 12, 2002 | 04:42 PM
Mil1ion's Avatar
Mil1ion
[updated:LAST EDITED ON 12-Jun-02 AT 05:42 PM (EST)]> Wow is this convenient. I was just about to enquire about
Good question.
I haven't figured out the answer yet though.
Anyone have
yes
I know I need the
[font color=red]
[/font]
Old Jun 12, 2002 | 05:14 PM
GORSTEP's Avatar
GORSTEP
Thanx Dennis.
Old Jun 12, 2002 | 05:26 PM
majic's Avatar
majic
1999stroke
May 16, 2014 09:19 AM
dyingtolive
19
Jan 31, 2012 06:37 AM
benmoderow
Dec 3, 2009 06:15 PM
Chad 73
Nov 30, 2002 07:47 PM
