Bronco II Ford Bronco II
need some info please.
Old Oct 7, 2005 | 07:43 PM
DANDEE1996's Avatar
DANDEE1996
does anyone know if a 5 speed manul tranny off a '87 broncoII will fit on a 351m\400
Old Oct 7, 2005 | 07:53 PM
slbc's Avatar
slbc
No, it won't fit. The newest trans and I think the only 5 speed that will bolt up would be a ZF 5 speed from a truck with a 460.
Old Oct 7, 2005 | 07:59 PM
DANDEE1996's Avatar
DANDEE1996
how do i figure out witch tranny is in this broncoII
Old Oct 7, 2005 | 08:03 PM
fordborn's Avatar
fordborn
can you get the trans code off the door sticker? With that we could tell you what it is.
Old Oct 7, 2005 | 10:55 PM
mrshorty's Avatar
mrshorty
Gut feel, if it's the original '87 transmission, it's likely a TK5, though there's a reasonable chance it's an FM145 or 146. The Ranger Station has a decent transmission identification page.
And, even if you did get either of those BII transmissions to bolt up to a those engines, those big engines would rip those little transmissions to shreds. Those trannys did ok behind the 2.9L; they are questionable for use behind a 4.0L; and I wouldn't even start to try them behind any V8.
Old Oct 9, 2005 | 11:54 AM
DANDEE1996's Avatar
DANDEE1996
thanks for the info everyone, that helps alot.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
