Bronco II Ford Bronco II
Rusty rear floor pan?
Old Oct 7, 2005 | 05:18 PM
Shiny62's Avatar
Shiny62
Today I noticed rear carpet was a little wet, come to find out the very rear of the floor panel is rusting thru in spot, right along the back edge. Has anyone else had this problem and what did you do to repair? Did you rivet in some new sheet metal? Any info is appreciated.
Thanks,
Shiny
Old Oct 7, 2005 | 11:35 PM
fordborn's Avatar
fordborn
Yes this is comon place for a rust through. On mine I just cut out the rusted area and welded in some sheet metal to replace it.
Old Oct 8, 2005 | 01:14 AM
ford390gashog's Avatar
ford390gashog
very common place for rust.
Old Oct 8, 2005 | 07:09 AM
Shiny62's Avatar
Shiny62
Fordborn,
Did you spray anything on the new sheetmetal. I was thinking about patching the area and using Por 15.
Shiny
Old Oct 8, 2005 | 07:14 AM
fordborn's Avatar
fordborn
yes I did go ahead and spray it with rust inhibitor primer paint, both sides. Just for precaution.
Old Oct 8, 2005 | 05:01 PM
mulik51's Avatar
mulik51
Hey. I didn't do the back but i did the front driver's side.
Just buy 1.5mm sheet metal and some selfscrewing bolts. Get a drill and metal scissors. Then you will need silicone paste(like from HomeDepot). I painted inside wilth black and did the bottom with underbody sprayer. Cut all the rust out. Then out the sheetmetal on, and cut becnd it to fit. Then put silicone on the edge and just screw it in with those selfscewing bolts. I put one each 1.5 inches.
Klim
Old Oct 8, 2005 | 07:37 PM
Shiny62's Avatar
Shiny62
I can see why rusting out in the back seat area is a problem. When I was cutting out the rusted metal I could see the flaw in the design. On the bottom of the frame there a 2 rectangular cut outs that leave the area behind the rear seat flooring wide open to having water and everyhing thown up into these holes. What a poor design.
Shiny
Old Oct 11, 2005 | 09:38 PM
rwmorrisonjr's Avatar
rwmorrisonjr
I have very little rust in the rear of the truck but some behind the parking brake controller and another spot by the left front of the seat next to the door. I did the bondo thing with undercoating on both sides in both places, but I like the bolt-on sheet metal idea for the hole in the floor pan. Would several layers of soda can aluminum provide the same strength/effect or should I use a single piece of 1.5 mm sheet metal for strength & durability?
Old Oct 11, 2005 | 09:48 PM
fordborn's Avatar
fordborn
I had some in the same area on mine. To repair I used 16ga steel and welded it in. While welding I used a body hammer to tap it into form with the rest of the floor pan. Then sprayed both side with rust inhibitor primer.
https://www.ford-trucks.com/user_gal...oid=74031&.jpg
Old Oct 12, 2005 | 08:05 AM
mulik51's Avatar
mulik51
Yeah, just want you to be aware: if you are leaking some H2O in when it is heavy raining, don't forget to put a water release bolt in the lowest place of the "new" floor panel.(learned it the hard way)
Klim
theboom
Apr 22, 2017 10:38 AM
sky Cowboy
British Columbia
1459
Mar 31, 2017 09:42 AM
reg1952
17
Mar 3, 2017 05:57 PM
aloonda
Sep 27, 2004 09:51 PM
BlueOvalFitter
Dec 24, 2002 11:13 PM
