Idle Reset?
Old Oct 7, 2005 | 01:15 PM
96DRW's Avatar
96DRW
Idle Reset?
Hi all,
I'm getting ready to do some winter maintainance on the battery of my 96 f350. I know that when I disconnect the battery the ECU is cleared. My question is, is there any procedure for reseting the idle and other ECU oriented stuff after reconnecting the battery? On my honda the procedure is to start the car, hold the RPM at 3000 until the radiator fan comes on, then drive it a bit (if I don't do this the idle is off). Would I do something similar with my truck? Thanks
Old Oct 7, 2005 | 02:58 PM
chmath's Avatar
chmath
When you put the new battery in I dont think there is anything special that you need to do....The ecu will relearn your driving habits as you go...
Old Oct 7, 2005 | 04:08 PM
KW160's Avatar
KW160
Originally Posted by 96DRW
Hi all,
My 1996 Owner's Manual says that you should let it idle for 2 minutes after you've replaced the battery.
Jrock909
Electrical Systems/Wiring
Apr 29, 2007 04:48 PM
Gurahl
1978 - 1996 Big Bronco
May 9, 2005 11:24 PM
juanjuan
Feb 26, 2004 05:09 AM
Blly177
Feb 22, 2004 03:38 PM
Rtpjunior
Jun 14, 2003 12:55 PM
